查看: 2029|回复: 1
[求助] MC仿真问题(环境问题)
发表于 2023-6-2 00:12:33 | 显示全部楼层 |阅读模式
工艺是 csmc0.18um,模型文件选的是:mc_mos、mc_bip、mc_res、mc_mcap、stat、stat_bip、stat_res、stat_mcap
出现以下问题,有人知道怎么解决吗?
WARNING (ADE-5033): Cannot find the environment variable 'check_simulator' for tool 'spectre.envOpts'.
        Its internal default value will be used.
WARNING (ADE-5034): Unable to access the default environment variables in the simulator's
        global .cdsenv file ('<your_install_dir>/tools/dfII/etc/tools/spectre/.cdsenv')
        because the file is missing or out-of-date. Till this problem exists, internal
        default values will be used for these environment variables during this session.
 楼主| 发表于 2023-6-22 19:49:31 | 显示全部楼层
顶一下,有没有大佬帮忙解答下关于蒙卡仿真的环境问题
GMT+8, 2025-10-4 01:49 , Processed in 0.011370 second(s), 3 queries , Gzip On, Redis On.
