查看: 9846|回复: 29
xcelium2009+spectre211 AMS数模仿真报缺license错误
发表于 2023-5-27 14:58:12 | 显示全部楼层 |阅读模式
xcelium2009+spectre211 AMS数模混仿报错, 两个软件单独使用都没问题,混合仿真时,报缺license,
一开始报缺少6个FEATURE 然后我在论坛里找到了个5种,只差一个Xcelium_safety_sim 20.00 没地方找,
再运行仿真,又提示Spectre_AMS_MMSIM 在从坛子里找到添加进去了,
再次运行仿真,直接提示 SPECTRE-209了,不知道该怎么办,
Command line:
    /eda/cadence/SPECTRE211/tools/bin/spectre -64 spiceModels.ams  \
        +config  \
        /eda/cadence/SPECTRE211/tools.lnx86/spectre/etc/configs/ams.cfg  \
        -ahdllibdir  \
        /root/simulation/AMS/TB_counter/maestro/results/maestro/Interactive.47/sharedData/CDS/ahdl/input.ahdlSimDB  \
        +logstatus +preset=mx +mt -raw ../psf -I/root/PROJECT/  \
        +ams_control=xcelium.d/AMSD/ams_ctrl/ams_ctrl_11818_alfa_ds01
Licensing Information:
[16:19:22.377257] Configured Lic search path (20.02-s004): /eda/license/cadence/cadence.dat
[16:19:22.073866] Periodic Lic check successful
Fatal error found by spectre.
    FATAL (SPECTRE-209): Cannot run the simulation because the required license could not be checked out. Check the license usage in the license server or use the license queuing feature (+lqtimeout <timeout_value> in the command line) to wait until the required license is available. For more information about +lqtimeout, type 'spectre -h'.
感觉是缺少AMS的授权,有没有好心的大佬给复制粘贴一下FEATURE
 楼主| 发表于 2023-5-27 22:19:21 | 显示全部楼层
已经解决啦,确实是license的问题,自己重新找了license.dat补充了两个feature就正常啦:
FEATURE Spectre_AMSD_Lk cdslmd 2100.000 permanent uncounted
FEATURE Spectre_AMS_MMSIM_Lk cdslmd 2100.000 permanent uncounted
现在把我正常使用的license.dat分享给大家,遇到问题大家多多讨论,把我的环境bashrc也贴出来给大家复制
###########################cadence###############################
export Cadence_Dir=/opt/cadence
export CDS_LIC_FILE=$Cadence_Dir/license/license.dat
#SPECTRE211--------------------------------------------------------------
export MMSIM_HOME=/opt/cadence/SPECTRE211
export PATH=$MMSIM_HOME/binPATH
export PATH=$MMSIM_HOME/tools/binPATH
export PATH=$MMSIM_HOME/tools/dfII/binPATH
export PATH=$MMSIM_HOME/tools/spectre/bin:$PATH
#XCELIUM2009----------------------------------------------------
export CDHOME=/opt/cadence
export XCELIUMDIR=$CDHOME/XCELIUM2009
export VRST_HOME=$CDHOME/XCELIUM2009
export LD_LIBRARY_PATH=$LD_LIBRARY_PATH:$CDHOME/XCELIUM2009/tools.lnx86/lib
alias irun="$CDHOME/XCELIUM2009/tools/bin/irun"
alias simv="$CDHOME/XCELIUM2009/tools/bin/simvision"
alias simvision="$CDHOME/XCELIUM2009/tools/bin/simvision -64 &"
alias ncvlog="$CDHOME/XCELIUM2009/tools/bin/ncvlog"
alias ncsim="$CDHOME/XCELIUM2009/tools/bin/ncvsim"
alias ncelab="$CDHOME/XCELIUM2009/tools/bin/ncelab"
alias ncvhdl_p="$CDHOME/XCELIUM2009/tools/bin/ncvhdl_p"
export SPECMAN_HOME=$XCELIUMDIR/components/sn
export SPECMAN_DIR=$SPECMAN_HOME/
export PATH="$PATH:$XCELIUMDIR/bin"
export PATH="$PATH:$XCELIUMDIR/tools.lnx86/bin"
export PATH="$PATH:$XCELIUMDIR/tools.lnx86/dfII/bin"
cadence.zip
79.98 KB, 下载次数: 656 , 下载积分: 资产 -2 信元, 下载支出 2 信元
点评
完美  发表于 2023-11-10 23:25
回复 支持 3 反对 0
发表于 2023-5-29 09:09:57 | 显示全部楼层
ok
发表于 2023-5-29 16:41:31 | 显示全部楼层
thanks
发表于 2023-7-3 09:23:45 | 显示全部楼层
thanks!
发表于 2023-7-3 10:40:31 | 显示全部楼层
https://alllicenseparser.com/eng ... m/cdslmd/index.html
这个网址可以找很多软件的feature,还挺好用的
发表于 2023-8-3 17:13:59 | 显示全部楼层
厉害了,我用了你的feature,也解决了问题
发表于 2023-8-31 12:12:03 | 显示全部楼层
FEATURE Spectre_ ...
c  家的 lic,用什么脚本 gererate呢
发表于 2023-9-1 13:52:57 | 显示全部楼层
你好, 这里面缺少Spectre X 和Spectre FX的license定义, 可方便提供学习呢
 楼主| 发表于 2023-9-1 17:17:19 | 显示全部楼层
我用的是一个 licgen.bat 的脚本生成的
GMT+8, 2025-12-15 09:00 , Processed in 0.025229 second(s), 5 queries , Gzip On, Redis On.
