查看: 3098|回复: 3
ICADVM201运行报错ERROR(EXPORER-5031)
发表于 2023-4-25 10:16:46 | 显示全部楼层 |阅读模式
各位大佬,新手运行案例文件,报错如下,请问这是软件配置问题还是模型设置问题呀?应该怎么解决呀?提前谢谢大家了,被折磨好几天了
ERROR(EXPLORER-5031) : While simulating run ExploreRun.0, point 1, test TestBench_1, received error:
Simulation Error:
Simulator failed to complete the simulation.
The simulator process returned a non-zero exit code, indicating failure.
The simulator could have crashed or intentionally returned to indicate an error.
Check the simulator log file for more information. Common causes:
1. Simulator may have crashed during exit even after reporting success in log file.
2. Abrupt automatic simulator termination (e.g., SIGKILL) because the simulator process has
exceeded resource limits, which can be specified in the distribution system or
by the kernel itself (e.g., the Linux OOMKiller).
3. Manual termination of the simulator process.
./runSimulation can be manually run in this directory to check the issue.
发表于 2024-1-2 13:59:58 | 显示全部楼层
请问找到原因了,最近突然遇到一模一样的问题
发表于 2024-2-7 17:01:57 | 显示全部楼层
XCELIUM23混合仿真 也遇到这样的问题
发表于 2025-7-1 10:05:17 | 显示全部楼层
楼主解决了吗
GMT+8, 2025-12-21 06:40 , Processed in 0.014590 second(s), 4 queries , Gzip On, Redis On.
