查看: 11078|回复: 42
ESD Robustness of High-Voltage NMOS(40V):Ming-Dou Ker
发表于 2008-1-17 20:54:28 | 显示全部楼层 |阅读模式
The Impact of N-Drift Implant on ESD Robustness of High-Voltage NMOS with Embedded SCR Structure in 40-V CMOS Process
Wei-Jen Chang1, Ming-Dou Ker1, Tai-Xiang Lai2, Tien-Hao Tang2, and Kuan-Cheng Su2
1Nanoelectronics and Gigascale Systems Laboratory
Institute of Electronics, National Chiao-Tung University, Hsinchu, Taiwan
2United Microelectronics Corp., Science-based Industrial Park, Taiwan
Abstract
The ESD robustness on different device structures and layout parameters of high-voltage (HV) NMOS has been investigated in 40-V CMOS process with silicon verification. It was demonstrated that a specific structure of HV n-type silicon controlled rectifier (HVNSCR) embedded into HV NMOS without N-drift implant in the drain region has the best ESD robustness. Moreover, due to the different current distributions in HV NMOS and HVNSCR, the trends of the TLP-measured It2 under different spacings from the drain diffusion to polygate are different.
abbr_16d843431281d93d01b3381a99d1e661.pdf
269.54 KB, 下载次数: 311 , 下载积分: 资产 -2 信元, 下载支出 2 信元
 楼主| 发表于 2008-1-17 20:55:49 | 显示全部楼层
Conclusion
The N-drift implant in the drain region and layout spacing (D) from the drain diffusion to polygate have been spilt to verify the ESD robustness of HV NMOS and HVNSCR in a given 40-V CMOS process. It has been found that the devices without N-drift implant have higher TLP-measured It2 than those with N-drift implant. For HVNSCR, the TLP-measured It2 can be improved over 6A by removing N-drift in the drain region. Due to the different current distributions in HV GGNMOS and HVNSCR, the dependences of TLP-measured It2 on the spacing of D are different.
Acknowledgment
The first author was supported by the MediaTek Fellowship, Hsinchu, Taiwan.
 楼主| 发表于 2008-1-17 20:56:51 | 显示全部楼层
Double Snapback Characteristics in High-Voltage
nMOSFETs and the Impact to On-Chip
ESD Protection Design
Ming-Dou Ker, Senior Member, IEEE, and Kun-Hsien Lin, Student Member, IEEE
EDL_Ker+Lin_Sept_2004.pdf
234.19 KB, 下载次数: 98 , 下载积分: 资产 -2 信元, 下载支出 2 信元
 楼主| 发表于 2008-1-17 20:58:07 | 显示全部楼层
Abstract—The double snapback characteristic in the highvoltage
nMOSFET under transmission line pulsing stress is found.
The physical mechanism of double snapback phenomenon in the
high-voltage nMOSFET is investigated by device simulation.With
double snapback characteristic in high-voltage nMOSFET, the
holding voltage of the high-voltage nMOSFET in snapback breakdown
condition has been found to be much smaller than the power
supply voltage. Such characteristic will cause the high-voltage
CMOS ICs susceptible to the latchup-like danger in the real
system applications, especially while the high-voltage nMOSFET
is used in the power-rail electrostatic discharge clamp circuit.
Index Terms—Double-diffused drain (DDD), electrostatic discharge
(ESD), high-voltage nMOSFET, lateral diffused MOS
(LDMOS), latchup.
 楼主| 发表于 2008-1-17 20:59:08 | 显示全部楼层
CONCLUSION
The double snapback characteristic in the high-voltage
nMOSFET has been investigated in this work. With both
measured and simulation results, the double snapback characteristics
in the 18-V and 40-V nMOSFETs have been fully
analyzed. The latchup-like issue between the power rails in the
high-voltage CMOS ICs has been confirmed by TLU test. How
to avoid the latchup-like failure of high-voltage nMOSFET
under normal circuit operating condition will be an important
challenge to on-chip ESD protection design for high-voltage
CMOS IC products.
发表于 2008-1-27 13:38:10 | 显示全部楼层
下来 看看
发表于 2008-2-17 22:27:48 | 显示全部楼层
hao
hao
hao
hao
发表于 2008-2-17 22:29:10 | 显示全部楼层
hao
hao
hao
hao
发表于 2008-2-19 00:00:45 | 显示全部楼层
感謝~~
发表于 2008-6-26 10:03:52 | 显示全部楼层
多谢多谢
GMT+8, 2025-12-28 23:56 , Processed in 0.020124 second(s), 5 queries , Gzip On, Redis On.
