查看: 2624|回复: 0
[求助] ADS momentum仿真报错
发表于 2023-4-20 09:08:12 | 显示全部楼层 |阅读模式
悬赏500资产未解决
通过动态链接在cadence下运行momentum,之前能正常仿真,但是突然报错。有人知道怎么解决吗?
License checkout took 0.044 sec
Momentum MomEngine_64 12.00.024 (*) built: Jan 14 2016
Copyright 1992-2016, Keysight Technologies
Simulation started on: Thu Apr 20 08:54:38 2023
Simulation Mode: RF
--- ERROR ---------------------------------------------------------------------
Tech Input proj.tch - line 1 : syntax error, unexpected $undefined, expecting UNITS.
The tech file should contain 3 blocks of data:
* the units definition, starting with the token UNITS
* the stack definition, starting with the token BEGIN_STACK
* the masks definition, starting with the token BEGIN_MASK
Unable to open the file proj.sub.
Check : - existence of file ;
        - file/directory read access permissions.
Unable to open the file proj.lmp.
GMT+8, 2025-12-30 02:08 , Processed in 0.014537 second(s), 3 queries , Gzip On, Redis On.
