查看: 3188|回复: 3
[求助] 画版图,原理图与版图不匹配
发表于 2023-4-5 11:04:20 | 显示全部楼层 |阅读模式
*WARNING* (BND-2005): Layout instances and terminals do not match the source.
Use 'XL Status' in the Navigator or run 'Connectivity - Check - Against Source' for more details.
If the bindings are correct, run the 'Update from Source' commands,
otherwise run 'Connectivity - Update - Binding'.
*** Checking layout cellview 'test/INV2_analoglib/layout' against source cellview 'test/INV2_analoglib/schematic'.  ***
INFO (LX-1018): Schematic pin 'gnd' has no corresponding layout pin.
INFO (LX-1018): Schematic pin 'vdd' has no corresponding layout pin.
INFO (LX-1018): Schematic pin 'vin' has no corresponding layout pin.
INFO (LX-1018): Schematic pin 'vout' has no corresponding layout pin.
INFO (LX-1001): Schematic instance 'M0' has no corresponding layout instance.
INFO (LX-1001): Schematic instance 'M1' has no corresponding layout instance.
INFO (LX-1024): Instance parameters match.
INFO (LX-1083): Implicit bus terminals match.
INFO (LX-1025): There are differences between the layout and the schematic.
Check messages above and markers in the layout for details.
*** Check Against Source complete. ***
发表于 2023-11-20 17:27:56 | 显示全部楼层
请问楼主这个问题解决了吗,最近遇到这个问题
发表于 2023-11-20 20:57:14 | 显示全部楼层
看起来像是连接关系对了但是用的器件对不上,你重新XL出来再画试试
发表于 2024-4-2 22:08:59 | 显示全部楼层
请问楼主解决了吗,最近也遇到了这个问题
GMT+8, 2025-12-19 20:13 , Processed in 0.014047 second(s), 5 queries , Gzip On, Redis On.
