查看: 2409|回复: 1
[转贴] How to convert a CDB library to an OA library
发表于 2023-3-23 15:15:43 | 显示全部楼层 |阅读模式
Jump to navigationJump to searchCDBCadence Data Base formatOAOpen Access format (now used in IC 6.1 and later)To convert a CDB library to an OA library:
  • First make sure that the DFII library is referenced in a cdb.lib file.
  • Make a new directory for OA and cd to it.
  • Next convert the technology library:
    cdb2oa -lib <techlib> -cdslibpath <path>
  • Then convert the library of interest:
    cdb2oa -lib <library> -cdslibpath <path>
For example, to convert the NCSU_TechLib_ami06 tech library from IC 5 to IC 6.1 do the following:
  • Create a temporary directory to work in and change to that directory.
    mkdir $HOME/tmpcd $HOME/tmp
  • Create directories cdb and oa directories and change directory to the cdb directory.
    mkdir cdbmkdir oacd cdb
  • Create a cds.lib file for the old NCSU_TechLib_ami06 tech library.
    vi cds.libEnter the following:
    DEFINE NCSU_TechLib_ami06 $CDS_SITE_CONFIG/CDK/ncsu-cdk-1.5.1/lib/NCSU_TechLib_ami06
  • Change directory to the oa directory.  This can be done using a relative path.
    cd ../oa
  • Execute cdb2oa to convert the tech library to the Open Access database format.
    cdb2oa -lib NCSU_TechLib_ami06 -cdslibpath ../cdb
  • You should have a message that looks like this.
    <--cut-->********************************************************************************Finished at:   Dec 13 19:45:39 201080 cells and 80 cellviews were translated from library 'NCSU_TechLib_ami06' in 114.1s.********************************************************************************
 楼主| 发表于 2023-6-21 10:08:19 | 显示全部楼层
51转61
GMT+8, 2025-12-25 21:37 , Processed in 0.013211 second(s), 4 queries , Gzip On, Redis On.
