查看: 2547|回复: 4
centos7 打不开innovus19.1
发表于 2023-3-22 11:29:21 | 显示全部楼层 |阅读模式
悬赏800资产未解决
[Thread debugging using libthread_db enabled]
Using host libthread_db library "/lib64/libthread_db.so.1".
Core was generated by `/tools/tools/cadence/INNOVUS191/tools.lnx86/innovus/bin/64bit/innovus -oa22'.
Program terminated with signal 6, Aborted.
#0  0x00007f61ca350387 in __GI_raise (sig=sig@entry=6) at ../nptl/sysdeps/unix/sysv/linux/raise.c:55
55          return INLINE_SYSCALL (tgkill, 3, pid, selftid, sig);
(gdb) bt
#1  0x00007f61ca351a78 in __GI_abort () at abort.c:90
#2  0x00007f61d2ddc0ad in __gnu_cxx::__verbose_terminate_handler() () from /tools/tools/cadence/INNOVUS191/tools.lnx86/lib/64bit/libstdc++.so.6
#3  0x00007f61d2dda0b6 in ?? () from /tools/tools/cadence/INNOVUS191/tools.lnx86/lib/64bit/libstdc++.so.6
#4  0x00007f61d2dda101 in std::terminate() () from /tools/tools/cadence/INNOVUS191/tools.lnx86/lib/64bit/libstdc++.so.6
#5  0x00007f61d2dda319 in __cxa_throw () from /tools/tools/cadence/INNOVUS191/tools.lnx86/lib/64bit/libstdc++.so.6
#6  0x00007f61d2e02807 in std::__throw_invalid_argument(char const*) () from /tools/tools/cadence/INNOVUS191/tools.lnx86/lib/64bit/libstdc++.so.6
#7  0x0000000004a51ec8 in getRedHatVersion() ()
#8  0x0000000004a526d5 in theApp::init_gui(Tcl_Interp*, bool, int (*)(Tcl_Interp*)) ()
#9  0x0000000004a528ff in app_init_proc(Tcl_Interp*) ()
#10 0x0000000018c195f7 in Tcl_MainEx ()
#11 0x0000000004a51533 in child_main(int, char**) ()
#12 0x0000000003fe487b in main ()
Starting program: /tools/tools/cadence/INNOVUS191/tools.lnx86/innovus/bin/64bit/innovus
/tools/tools/cadence/INNOVUS191/tools.lnx86/innovus/bin/64bit/innovus: error while loading shared libraries: libcdsCommon_sh.so: cannot open shared object file: No such file or directory
[Inferior 1 (process 327348) exited with code 0177]
发表于 2023-3-22 11:36:48 | 显示全部楼层
此帖仅作者可见
发表于 2023-3-22 12:56:04 | 显示全部楼层
此帖仅作者可见
 楼主| 发表于 2023-3-22 13:21:43 | 显示全部楼层
此帖仅作者可见
 楼主| 发表于 2023-3-22 13:22:32 | 显示全部楼层
此帖仅作者可见
GMT+8, 2025-12-19 12:19 , Processed in 0.014503 second(s), 3 queries , Gzip On, Redis On.
