查看: 3167|回复: 3
[求助] virtuoso版图显示pcell eval failed(仅仅是设计电路中的元件会这样)
发表于 2023-2-17 17:33:38 | 显示全部楼层 |阅读模式
log里面显示:(奇怪的是,仅仅是我设计电路中的元件导入进layout会显示"pcell Eval Failed",其他的元件就可以正常显示出本来的版图样子)
INFO (LX-1030): Run Connectivity - Check - Against Source for more details.
INFO (LCE-1009): The cell verifier found no violations.
INFO (LX-1063): Building the layout generation form...
*WARNING* (LX-2003): Cannot create instance terminal on layout instance 'C4' because the instance master 'tsmcN65/mimcap_woum_rf/layout' does not have a corresponding terminal 'BULK'.
*WARNING* (LX-2003): Cannot create instance terminal on layout instance 'C4' because the instance master 'tsmcN65/mimcap_woum_rf/layout' does not have a corresponding terminal 'MINUS'.
*WARNING* (LX-2003): Cannot create instance terminal on layout instance 'C4' because the instance master 'tsmcN65/mimcap_woum_rf/layout' does not have a corresponding terminal 'PLUS'.
*WARNING* (LX-2003): Cannot create instance terminal on layout instance 'C5' because the instance master 'tsmcN65/mimcap_woum_rf/layout' does not have a corresponding terminal 'BULK'.
*WARNING* (LX-2003): Cannot create instance terminal on layout instance 'CB' because the instance master 'tsmcN65/mimcap_woum_rf/layout' does not have a corresponding terminal 'MINUS'.
*WARNING* (LX-2003): Cannot create instance terminal on layout instance 'CB' because the instance master 'tsmcN65/mimcap_woum_rf/layout' does not have a corresponding terminal 'PLUS'.
*WARNING* (LX-2003): Cannot create instance terminal on layout instance 'M1n.1' because the instance master 'tsmcN65/nmos_rf/layout' does not have a corresponding terminal 'B'.
*WARNING* (LX-2003): Cannot create instance terminal on layout instance 'M1n.1' because the instance master 'tsmcN65/nmos_rf/layout' does not have a corresponding terminal 'D'.
*WARNING* (LX-2006): There were errors or warnings during layout generation.
 楼主| 发表于 2023-2-18 08:49:28 | 显示全部楼层
没有伙伴知道吗
发表于 2023-2-19 00:23:36 | 显示全部楼层
我也是这个问题,楼主要是解决问题了,记得发布一下解决办法哦
 楼主| 发表于 2023-3-9 15:18:52 | 显示全部楼层
换了一个工艺库就好了
GMT+8, 2025-11-29 02:37 , Processed in 0.017834 second(s), 4 queries , Gzip On, Redis On.
