查看: 11531|回复: 38
在RHEL/Centos/Rocky 8.x系统上部署EDA软件的尝试
发表于 2023-1-10 23:34:29 | 显示全部楼层 |阅读模式
RHEL/Centos/Rocky 8.x部分软件包版本更新,原有的部分7.x系统依赖在8.x下不能直接装包解决,需要手动打几个软链接:
在/usr/lib64下:
ln -s libssl.so.1.0.2o libssl.so
ln -s libcrypto.so.1.0.2o libcrypto.so
ln -s libdb-5.3.so libdb-4.7.so
配合系统默认repo和EPEL中的包可解决ICADVM201不能正常启动的问题。INNOVUS211等不依赖这些包,8.x下可直接启动。
其他软件以及进一步的测试结果如果后续遇到问题再补充。
发表于 2023-1-11 09:23:51 | 显示全部楼层
多谢楼主勇于尝试,并且给出方案。赞一个
发表于 2023-1-11 09:33:14 | 显示全部楼层
Thanks for sharing, but using the OS version supported by EDA S/W is a better choice.
 楼主| 发表于 2023-1-11 10:42:16 | 显示全部楼层
Currently RHEL 7 is better, but due to the old kernel version the compatibility between RHEL 7 and some new hardwares could become a problem. Since RHEL 7 will EOL in 2024, the adoption of RHEL 8 on newly deployed computing platforms is just a matter of time. Btw Cadence claims that the RHEL 8 is supported. Im not sure why it needs some manual tweaks to bring ICADVM201 up.
发表于 2023-1-11 22:01:02 | 显示全部楼层
 楼主| 发表于 2023-1-12 10:53:52 | 显示全部楼层
See that, thanks. Now everything makes sense. The computing platform support roadmap says RHEL 8 is fully supported, which is misleading.
发表于 2023-1-12 14:18:44 | 显示全部楼层
Thanks for sharing
发表于 2023-2-6 15:24:02 | 显示全部楼层
IC618只需要最后一步 libdb即可
Rocky llinux 还要修改checkSystem。
发表于 2023-2-8 19:56:55 | 显示全部楼层
ic618不止只有最后一个吧,也少了好几个软连接。
发表于 2024-2-17 20:40:50 | 显示全部楼层
请问又修改checkSystem的教程吗
GMT+8, 2025-12-17 22:45 , Processed in 0.042396 second(s), 3 queries , Gzip On, Redis On.
