查看: 1935|回复: 0
PRO_SAP 22.5 x64 Full Features
发表于 2023-1-6 06:45:47 | 显示全部楼层 |阅读模式
PRO_SAP 22.5 x64
PRO_SAP: PROfessional Structural Analysis Program is one of the best programs for structural analysis. PRO_SAP is a professional structural analysis program that meets the needs of each designer. It can be used to design structures made of different materials and is available in differ different needs.
PRO_SAP is a professional structural analysis program that offers several levels of performance. The PRO_SAP base module allows for static modeling and analysis of trusses, beams, columns, membranes, walls, shells, solid elements, slabs, beams, bases, candles, damping systems. Linear seismic analysis can be done with the option of producing computational reports and maintenance programs. In addition to the main module, PRO_SAP can be upgraded with 10 optional modules for maximum customization.
PRO_SAP program features and features:
  • Design of reinforced concrete, steel, building, armed building, timber, XLAM , semi-built beams, large walls with light reinforcement, FRP reinforcements for buildings and reinforced concrete structures، Steel and concrete reinforcements for existing concrete existing structure, so structure . structure cover, fire resistance.
  • Che exisiting buildings, insulation, soil and structure cover, fire resistance.
  • Apply Italian rules to Eurocodes. Manage elasto-plastic, nonlinear geometric elements, balance stability, construction steps ,
  • Manage elasto-plastic, nonlinear geometric elements, balance stability, construction steps uro pressure analysis, dampers.
  • Draws reinforced concrete structures, steel and wood.
  • Create Computational reports, geotechnical reports, maintenance programs. Details of floors, stairs, ceilings, elevator cores, building rings
  • Design and approval of steel elements ( Tires, columns, trusses ) with ULS methods or allowable stress for new and existing buildings. Calculation report
  • Dynamic linear seismic analysis, response spectrum analysis, arc analysis.
  • Geotechnical analysis, calculation of Winkler module for deep and deep pies, calculation of the session. Geotechnical approval and report
If you are interested in the full licensed software PRO_SAP 22.5 x64 with full feature license and tutorial examples, then do well to contact      fast.forever24@gmail.com
PLEASE NOTE
Also, if you are interested in other EDA software like:   EMPIRE XPU 8.1.3 , Remcom XFDTD 7.10.1, Remcom XGTD 3.1.2, Remcom Wireless Insite 3.3.5, Remcom WaveFarer Radar Software 2.1, Sonnet Suite Pro 18.56 and ASN Filter Designer 5.2.1, Tetcos Netsim Professional 13.1, DigacSilent 2022, VPI Photonic TransmissionMaker 11.1, Optenni Lab 5.0, EMTP-RV 4.2.1, SpiceVision 7.0 and StarVision, ETAP Professional 21, PSSE 35.4.1 etc. please contact   fast.forever24@gmail.com
GMT+8, 2025-10-7 20:49 , Processed in 0.017695 second(s), 5 queries , Gzip On, Redis On.
