查看: 3009|回复: 2
[求助] Layout lef提取问题求助
发表于 2023-1-5 17:10:15 | 显示全部楼层 |阅读模式
在抽取lef文件时,使用abstract软件,在第二步运行结束后,出现“Extraction has been stopped because the number of shapes that were extracted for net ‘VCC’  exceeds  the current extraction limit of ‘3000’。Use the "ExtractShapeLimit" option to increase the extraction limit and rerun the command.” error,这个应该怎么修改呢? 2.png 3.png
发表于 2023-1-5 17:58:49 | 显示全部楼层
可以在abstract 里输
absSetOption("ExtractShapeLimit" "100000000")
或者在启动abstract 前输
limit stacksize umlimited
 楼主| 发表于 2023-1-5 19:25:45 | 显示全部楼层
firewolf223 发表于 2023-1-5 17:58
可以在abstract 里输
或者在启动abstract 前输
试了下可以跑通啦,谢谢大佬
GMT+8, 2025-12-16 12:27 , Processed in 0.015172 second(s), 4 queries , Gzip On, Redis On.
