查看: 2875|回复: 4
[求助] 求帮忙下载几篇论文
发表于 2023-1-1 17:32:17 | 显示全部楼层 |阅读模式
悬赏25资产未解决
求道友帮忙下载几篇论文,感谢
1、A 6.3-8.7 GHz Phase-Locked Loop in 65nm CMOS
2、Additive High-Speed Synchronization Techniques in PLL Systems
3、A 0.8-V, 2.55-GHz, 2.62-mW Charge-Pump PLL With High Spectrum Purity
4、A 25.8GHz Integer-N PLL With Time-Amplifying Phase-Frequency Detector Achieving 60fsrms Jitter, -252.8dB FoMJ, and Robust Lock Acquisition Performance
5、A 3.37-7.18 GHz Wideband PLL with Multi-core VCO in 180-nm CMOS
 楼主| 发表于 2023-1-2 11:04:18 | 显示全部楼层
已解决
发表于 2023-1-5 11:33:07 | 显示全部楼层
好东西能分享出来吗?????
 楼主| 发表于 2023-1-6 22:08:51 | 显示全部楼层
狱火虫 发表于 2023-1-5 11:33
好东西能分享出来吗?????
2021A_6.3-8.7_GHz_Phase-Locked_Loop_in_65nm_CMOS.pdf (3.8 MB , 下载次数: 3 )
2022A_0.8-V_2.55-GHz_2.62-mW_Charge-Pump_PLL_With_High_Spectrum_Purity.pdf (2.71 MB , 下载次数: 4 )
2022A_3.37-7.18_GHz_Wideband_PLL_with_Multi-core_VCO_in_180-nm_CMOS.pdf (737.91 KB , 下载次数: 2 )
2022A_25.8GHz_Integer-N_PLL_With_Time-Amplifying_Phase-Frequency_Detector_Achiev.pdf (1.21 MB , 下载次数: 3 )
Additive_High-Speed_Synchronization_Techniques_in_PLL_Systems2022.pdf (1.33 MB , 下载次数: 2 )
道友你好,这是上面的五篇PLL论文,四篇2022年的,一篇2021年的
发表于 2023-1-7 09:36:01 | 显示全部楼层
非常感谢
GMT+8, 2025-12-22 10:50 , Processed in 0.017190 second(s), 5 queries , Gzip On, Redis On.
