查看: 1855|回复: 6
[原创] 安装Virtuoso之后启动出现了以下问题,请问该怎么解决
发表于 2022-12-11 13:40:49 | 显示全部楼层 |阅读模式
安装Virtuoso之后启动出现了以下问题,请问该怎么解决?
[ic@ic TSMC_018um_1v8-3v3_1P6M]$ virtuoso
ERROR: $OA_HOME/bin
(opt/Cadence/ICADVM201/share/oa/bin)
is not a valid OA bin directory.
Check your OA installation or update the value
of OA_HOME to point to a valid OA installation.
See the "OpenAccess Installation and Configuration Guide"
for more information.
virtuoso:   ERROR: No proper OA2.2 installation found. Fix the errors reported by cdsGetOABinPath.
virtuoso:    INFO: Note that OpenAccess (OA) requires running the Configure phase.
virtuoso:          See the "OpenAccess Installation and Configuration Guide" before
virtuoso:          you complete the configuration step. This manual is included with
virtuoso:          the Cadence product documentation.
发表于 2022-12-12 23:29:41 | 显示全部楼层
要先转成oa格式
发表于 2022-12-16 11:32:30 | 显示全部楼层
你在安装时有弹窗提示跟这个相关,不确定有用没用关心,我都是选的n
发表于 2022-12-16 11:33:50 | 显示全部楼层
CDB toOA?
 楼主| 发表于 2022-12-16 13:13:18 | 显示全部楼层
我安装的时候没有
发表于 2024-12-19 10:04:23 | 显示全部楼层
感谢,我也是想要的
 楼主| 发表于 2024-12-22 10:57:55 | 显示全部楼层
真诚的小鲸鱼 发表于 2024-12-19 10:04
感谢,我也是想要的
OA路径写成软件自带最新的就行了。
GMT+8, 2025-9-16 05:25 , Processed in 0.014106 second(s), 3 queries , Gzip On, Redis On.
