查看: 1675|回复: 3
[求助] 求助一篇ieee论文 Modified 555 Timer IC Using Only Two Comparators, Thank you very much.
发表于 2022-11-26 15:58:01 | 显示全部楼层 |阅读模式
求助一篇ieee论文
https://ieeexplore.ieee.org/document/9649709
All Authors
Theodora Valerie; Dodi Garinto; Mudrik Alaydrus; Taufik Taufik; Eka Samsul Ma'arif
Abstract:
This paper proposed a modified 555 timer IC with only two comparators by eliminating the discharge transistor and SR flip-flop. A periodic square waveform can be generated by utilizing the interconnection of two comparators to provide ‘Set’ and ‘Reset’ conditions to each other. The simulation and experimental results confirm that the clock frequency generated by the modified 555 timer circuit is significantly higher and duty cycle adjustment can be made more precise and flexible than the commercially available 555 timer circuit. A frequency in the band of 1MHz to 89MHz can be generated by replacing the resistors, capacitor, and comparator specification in all possible configurations. As a result, a lower cost and higher efficiency on-chip reference clock generator can be realized to fulfill versatile future application needs.
Published in: 2021 1st International Conference on Electronic and Electrical Engineering and Intelligent System (ICE3IS)
Date of Conference: 15-16 October 2021
Date Added to IEEE Xplore: 27 December 2021
ISBN Information:
INSPEC Accession Number: 21431562
DOI: 10.1109/ICE3IS54102.2021.9649709
Publisher: IEEE
Conference Location: Yogyakarta, Indonesia
发表于 2022-11-26 16:30:11 | 显示全部楼层
Modified_555_Timer_IC_Using_Only_Two_Comparators.pdf (5.13 MB , 下载次数: 24 )
回复 支持 2 反对 0
 楼主| 发表于 2022-11-26 17:46:31 | 显示全部楼层
发表于 2022-11-26 17:49:12 | 显示全部楼层
谢谢分享
GMT+8, 2025-12-21 06:41 , Processed in 0.014894 second(s), 5 queries , Gzip On, Redis On.
