楼主在做spice仿真老化路径。先是用primetime的spice_deck命令跑出c499_fresh_path.spi文件,后面在把c499_fresh_path.spi文件放到hspice去仿真,命令是 hspice -i c499_fresh_path.spi。 但是hspice报错 **error** stop simulation by signal = 6,hspice的仿真结果如下:
[crazy@crazy_one project2]$ hspice -i c499_fresh_path.spi
Using: /opt/synopsys/hspice_2017/hspice/linux64/hspice -i 'c499_fresh_path.spi'
****** HSPICE -- N-2017.12-SP2 linux64 (May 24 2018) ******
Copyright (c) 1986 - 2022 by Synopsys, Inc. All Rights Reserved.
This software and the associated documentation are proprietary
to Synopsys, Inc. This software may only be used in accordance
with the terms and conditions of a written license agreement with
Synopsys, Inc. All other use, reproduction, or distribution of
this software is strictly prohibited.
Input File: c499_fresh_path.spi
Command line options: /opt/synopsys/hspice_2017/hspice/linux64/hspice -i c499_fresh_path.spi
lic:
lic: FLEXlm: SDK_11.6.9.3
lic: USER: crazy HOSTNAME: crazy_one
lic: HOSTID: 000c29efa373 PID: 9179
lic: Using FLEXlm license file:
lic: /opt/synopsys/scl_2016/synopsys.dat
lic: Checkout 1 hspice
lic: License/Maintenance for hspice will expire on 31-dec-2030/2030.12
lic: NODE LOCKED license on hostid 000c29efa373
lic:
Init: hspice initialization file: /opt/synopsys/hspice_2017/hspice/hspice.ini
terminate called after throwing an instance of 'io::fortran_adaptor::MemErrType'
1****** HSPICE -- N-2017.12-SP2 linux64 (May 24 2018) ******
****** job statistics summary tnom= 0.000 temp= 0.000 ******
****** Machine Information ******
CPU:
model name : Intel(R) Core(TM) i5-10400 CPU @ 2.90GHz
cpu MHz : 2903.998
OS:
Linux version 2.6.32-754.31.1.el6.x86_64 (mockbuild@x86-01.bsys.centos.org) (gcc version 4.4.7 20120313 (Red Hat 4.4.7-23) (GCC) ) #1 SMP Wed Jul 15 16:02:21 UTC 2020
****** HSPICE Threads Information ******
Command Line Threads Count : 1
Available CPU Count : 6
Actual Threads Count : 1
****** Circuit Statistics ******
# nodes = 0 # elements = 0
# resistors = 0 # capacitors = 0 # inductors = 0
# mutual_inds = 0 # vccs = 0 # vcvs = 0
# cccs = 0 # ccvs = 0 # volt_srcs = 0
# curr_srcs = 0 # diodes = 0 # bjts = 0
# jfets = 0 # mosfets = 0 # U elements = 0
# T elements = 0 # W elements = 0 # B elements = 0
# S elements = 0 # P elements = 0 # va device = 0
# vector_srcs = 0 # N elements = 0
****** Runtime Statistics (seconds) ******
analysis time # points tot. iter conv.iter
op point 0.00 1 0
readin 0.00
errchk 0.00
setup 0.00
output 0.00
peak memory used 0.00 megabytes
total cpu time 0.00 seconds
total elapsed time 11.08 seconds
job started at 01:36:49 11/08/2022
job ended at 01:37:00 11/08/2022
lic: Release hspice token(s)
lic: total license checkout elapse time: 10.93(s)
