查看: 4659|回复: 13
[求助] Redhawk static ERROR GEN-010导致进程中断
发表于 2022-11-2 15:58:32 | 显示全部楼层 |阅读模式
在redhawk static仿真时报错:Failed to set up static simulation
导致进程运行中断。
通过初步测试每个输入文件,可以判断是一个block的def导致的中断。
但是具体是def的什么内容导致的呢,没有找到具体原因。
有没有路过的大佬指点迷津。
  1. Program /home/RHv18/bin/asimplus_static of Apache Design Solutions, Inc. with Released Date: 02/15/2018
  2. INFO(SIM-S03I): Read in resistive network...
  3. INFO(SIM-S04I): Read in current distribution...
  4. rm .apache///apache.res
  5. rm .apache///apache.res.gz
  6. rm .apache///apache.nloc
  7. rm .apache///apache.nloc.gz
  8. INFO(SIM-02I): Check circuit topology...
  9. INFO(SIM-S01I): Start static analysis with 4824546 nodes and 7699152 resistors...
  10. MEMORY USAGE (AsimPlus Static BFS): 418 MBytes
  11. ERROR(SIG-004): Program /home/RHv18/bin/asimplus_static terminated with signal SIGILL. Illegal instruction.
  12. MEMORY USAGE (Finish static simulation): 9319 MBytes
  13. TOTAL CPU TIME: 0 hrs 6 mins 24 secs
  14. WALLTIME: 5 mins 50 secs.
  15. ERROR(GEN-010): Static simulation has failed (error code 4)..
  16. SUMMARY:
  17.   WARNING(CCL-115): total 1
  18.   ERROR(GEN-010): total 1
  19.     DIAGNOSIS: Please check data preparation or contact Apache.
  20. There are a total of 1 WARNINGs. Please check <adsRpt/Warn/redhawk.warn.2022-11-02-15:09:05> for details.
  21. There are a total of 1 ERRORs. Please check <adsRpt/Error/redhawk.err.2022-11-02-15:09:05> for details.
  22. ***********************************************************
  23. ****   Finish Static Analysis
  24. ***********************************************************
  25. MEMORY USAGE (static analysis): 9018 MBytes
  26. TOTAL CPU TIME: 0 hrs 6 mins 24 secs
  27. WALLTIME: 5 mins 50 secs.
  28. ***********************************************************
  29. ****   Finish RedHawk Static Flow
  30. ***********************************************************
  31. ERROR(GEN-010): Failed to set up static simulation.
  32. Tcl command evaluation failed.
  33. Batch command execution failed.
  34. RedHawk application is ended.
  35.
    复制代码
 楼主| 发表于 2022-11-4 11:06:09 | 显示全部楼层
顶顶 有路过的大佬吗
发表于 2022-11-4 15:20:29 | 显示全部楼层
检查一下输出这个DEF的BLOCK本身的PG连接情况
是否存在大量的unconnected inst PGPin ,是否有创建电源地端口,输出DEF的版本建议5.8以上
或者是这个BLOCK和顶层之间是否有问题,你可以试试运行redhawk到提取完成pg后暂停,然后用redhawk检查下design
 楼主| 发表于 2022-11-7 09:08:59 | 显示全部楼层
是否存在大量的unconnected inst PGPin ,是否有创建电源地端 ...
前辈。请问这个check design的具体命令是什么呢
 楼主| 发表于 2022-11-7 14:07:22 | 显示全部楼层
已解决,并设上global
> 是否有创建电源地端口
有电源端子。
>输出DEF的版本建议5.8以上
block出的def 用5.7, 5.8都试了。
>BLOCK和顶层之间是否有问题
设计中不存在short。
补充:
block单独跑static 能正常出结果。
整个design (block+top)的dynamic能正常出结果。
请问前辈,是否还有其他解决办法呢。
 楼主| 发表于 2022-11-11 09:21:23 | 显示全部楼层
顶顶
发表于 2022-11-13 10:35:14 | 显示全部楼层
已解决,并设上global
> 是否有创建电源地端口
就是打个比方:
setup mode static
improt <top_design_name>.gsr
power caculation
power extract -c -r -l
运作到这里就可以了,然后在redhawk 下拉菜单
view-> connectity里面,看short、unconnected inst、unconnected wire/via等是否正常,
同时adsRpt/目录下,以apache.开头的文件说明输入数据异常,以top design name开头的说明design异常,都可以check下
发表于 2022-11-13 10:47:06 | 显示全部楼层
前辈不敢当,同行友好交流另外 看到你说单独Block能过static analysis,block+top能过dynamic分析,那就说明输入数据没有大问题毕竟动态都跑通了,同样的流程静态分析不应该有问题的
很是诡异,我还没遇到过这种情况
曾经我一个flow静态过了,动态老崩溃,后来检查是大量inst floating,静态可以waive这个错误,动态就会导致崩溃
倒过来的 说真的没见过,如果你已经解决了,分享一下原因
 楼主| 发表于 2022-11-17 11:20:26 | 显示全部楼层
豆豆熊 发表于 2022-11-13 10:47
前辈不敢当,同行友好交流另外 看到你说单独Block能过static analysis,block+top能过dynamic分析,那就 ...
还没有解决,,
不知道是什么奇怪的问题
发表于 2022-11-22 09:38:19 | 显示全部楼层
你应该把这个发出来 这里面是比较详细的,redhawk.err.2022-11-02-15:09:05
GMT+8, 2025-10-12 07:12 , Processed in 0.018893 second(s), 3 queries , Gzip On, Redis On.
