查看: 2099|回复: 2
[求助] 谁有 ARM Developer Suite 1.2 linux 版本能否分享一下
发表于 2022-10-26 16:39:25 | 显示全部楼层 |阅读模式
谁有 ARM Developer Suite 1.2 linux 版本能否分享一下?
或者有其他版本的linux 注册机也可以。 我之前找了个一个 ArmLicGen ,那玩意根本用不了。。。。 哪位大佬给分享个linux下的可用版本,多谢
 楼主| 发表于 2023-1-18 20:14:41 | 显示全部楼层
备注一下,论坛里 https://bbs.eetop.cn/thread-299179-1-1.html?id=2930183678175 这个帖子里没有linux,免得浪费积分。这个是我下载后解压的内容:
eetop.cn_rvds4.crack.part2\rvds4.crack
Mode                 LastWriteTime         Length Name
-a----        2008/12/21      7:17              0 com.arm.profiler.models.windows_2.0.0.200809121341.jar
-a----        2008/12/21      7:28        2633788 com.arm.profiler.plugin_2.0.0.200809121341.jar
-a----        2008/12/21     18:49           1374 crack.bat
-a----        2008/12/21     18:33         200747 ecc.exe
-a----         2008/2/10     17:03           5120 FlexLMsearch.exe
-a----         2011/6/18     10:52            301 readme.txt
-a----         2011/6/18     10:41           9384 rvds.dat
 楼主| 发表于 2023-1-18 20:19:36 | 显示全部楼层
包括上面那个帖子的6楼的压缩包:
eetop.cn_LinuxPatches.rar\LinuxPatches\DCC\patch-rvi-dcc-2.6.19-arm2.gz\patch-rvi-dcc-2.6.19-arm2 是代码补丁,具体内容如下:
Debugging support over RVI-DCC
This patch adds debugging support over RVI-DCC. It consists of kgdb
support and Ethernet over DCC driver. This patch requires at least
version 1.5 of the RV-ICE firmware.
Signed-off-by: Robert Walker <Robert.Walker@arm.com>
Signed-off-by: Catalin Marinas <catalin.marinas@arm.com>
arch/arm/Kconfig.debug             |   51 ++
arch/arm/boot/compressed/misc.c    |  194 +++++--
arch/arm/common/Makefile           |    2
arch/arm/common/rvidcc_common.c    |  788 +++++++++++++++++++++++++++
arch/arm/common/rvidcc_config.h    |  176 ++++++
arch/arm/common/rvidcc_interface.h |  182 ++++++
arch/arm/common/rvidcc_linux.c     | 1035 ++++++++++++++++++++++++++++++++++++
include/asm-arm/hardware/rvidcc.h  |   35 +
8 files changed, 2418 insertions(+), 45 deletions(-)
太多了,省略更多。。。。
GMT+8, 2025-12-18 17:51 , Processed in 0.014710 second(s), 4 queries , Gzip On, Redis On.
