查看: 41571|回复: 365
[资料] 【视频】Middlebrook博士面向模拟电路设计人员的技术治疗
发表于 2022-10-16 16:27:51 | 显示全部楼层 |阅读模式
模拟电路设计人员技术治疗视频演示
Dr. Middlebrook's Technical Therapy for Analog Circuit Designers, featuring Design-Oriented Analysis "How to get more results for less work".
视频链接:
游客 ,如果您要查看本帖隐藏内容请回复
contents:
Chapter 1 - Realization: design is the reverse of analysis
Chapter 1A - Field Effect Transistors and Bipolar Junction Transistors are Charge-Controlled Devices
Chapter 2 - Low Entropy Expressions: The Key to D-OA
Chapter 3 - Normal and Inverted Poles and Zeros
Solutions 3.1 - Practice the relationships between asymptote constructions and factored pole-zero forms
Solutions 3.2 - Practice the input and output impedance of Zi and Zo in factored pole-zero form, and sketching the magnitude and phase asymptotes, for each of the two networks
Chapter 4 - Finding factored pole-zero from by eyeball
Solutions 4.1
Chapter 5 - Building low entropy expressions with minimum work
Solutions 5.1
Chapter 6 - Null Double Injection (NDI) and the Extra Element Theorem (EET)
Chapter 7 - The Input/Output Impedance Theorem
Solution 7.1
Chapter 8 - Feedback: An Improved Formula
Chapter 9 - All about T
Chapter 10 - How much Phase Margin is Necessary?
Chapter 11 - How to Measure T
发表于 2022-10-16 19:02:35 | 显示全部楼层
3q for share~
发表于 2022-10-16 19:21:30 | 显示全部楼层
3q for share~
发表于 2022-10-16 21:56:04 | 显示全部楼层
Thanks for sharing
发表于 2022-10-17 03:58:41 | 显示全部楼层
赞!楼主辛苦了
发表于 2022-10-18 18:56:16 | 显示全部楼层
Thanks
发表于 2022-10-18 21:18:04 | 显示全部楼层
good thanks
发表于 2023-1-29 21:18:16 | 显示全部楼层
看看
发表于 2023-7-27 15:56:55 | 显示全部楼层
thank you very much
发表于 2023-7-27 16:03:59 | 显示全部楼层
赞!楼主辛苦了
GMT+8, 2025-12-21 07:12 , Processed in 0.018980 second(s), 4 queries , Gzip On, Redis On.
