查看: 3316|回复: 6
求一个Cadence Genus 17.20 的 license
发表于 2022-10-13 05:27:40 | 显示全部楼层 |阅读模式
悬赏2000资产已解决
我在Ubuntu 20.04上装了Genus 17.20,命令行模式下可以运行但是一直报告 license 失效,哪位大佬给发一份对 17.20 版本有效的 license?
另外,我是直接在 ~/.bashrc 中添加了这两行:
export LM_LICENSE_FILE="/usr/cadence/license/cadence.txt"
export HOST=$(hostname)
然后直接启动的Genus,并没有打 1patch。一个原因是我查到几个帖子说 1patch 对新版的Genus和Innovus不起作用,另一个原因是我之前用同样的办法是可以正常使用Cadence Stratus HLS 的。
我的 license 文件里Genus的feature如下:
FEATURE Genus_CPU_Opt cdslmd 2100.000 permanent uncounted 1DD45D6CBC067AEEAEBB \
        VENDOR_STRING=UHDERM vendor_info=31-dec-2015 ISSUER=CDNS216dfa12b695947d596a697549785772 \ ISSUED=31-dec-2015 HOSTID=ANY SN=2015-12-31T08:18:28:248 SIGN2=0 V7.1_LK=0
FEATURE Genus_Low_Power_Opt cdslmd 2100.000 permanent uncounted 1DD45D6CBC067AEEAEBB \
FEATURE Genus_Physical_Opt cdslmd 2100.000 permanent uncounted 1DD45D6CBC067AEEAEBB \
FEATURE Genus_Synthesis cdslmd 2100.000 permanent uncounted 1DD45D6CBC067AEEAEBB \
        VENDOR_STRING=UHD:PERM vendor_info=31-dec-2015 ISSUER=CDNS216dfa12b695947d596a697549785772 \ ISSUED=31-dec-2015 HOSTID=ANY SN=2015-12-31T08:18:28:248 SIGN2=0 V7.1_LK=0
FEATURE Virtuoso_Digital_Implem cdslmd 2100.000 permanent uncounted 1DD45D6CBC067AEEAEBB \
FEATURE Virtuoso_Digital_Implem_XL cdslmd 2100.000 permanent uncounted 1DD45D6CBC067AEEAEBB \
FEATURE Virtuoso_Digital_Signoff_Power cdslmd 2100.000 permanent uncounted 1DD45D6CBC067AEEAEBB \
执行Genus后的打印信息如下:
TMPDIR is being set to /tmp/genus_temp_3862_RyzenTR_idwwwoqq808_aBMEOb
Cadence Genus(TM) Synthesis Solution.
Copyright 2017 Cadence Design Systems, Inc. All rights reserved worldwide.
Cadence and the Cadence logo are registered trademarks and Genus is a trademark
of Cadence Design Systems, Inc. in the United States and other countries.
Version: 17.20-p003_1, built Wed Nov 29 2017
Options: -no_gui
Date:    Wed Oct 12 15:32:34 2022
Host:    RyzenTR (x86_64 w/Linux 5.8.0-53-generic) (64cores*128cpus*1physical cpu*AMD Ryzen Threadripper 3990X 64-Core Processor 512KB) (263878296KB)
OS:      CentOS release 6.4 (Final)
Checking out license: Genus_Synthesis
License 'Genus_Synthesis' (main version: 17.2, alternate version: 17.2) checkout failed.
Checking out license: Virtuoso_Digital_Implem
License 'Virtuoso_Digital_Implem' (main version: 17.1, alternate version: 17.1) checkout failed.
Checking out license: Virtuoso_Digital_Implem_XL
License 'Virtuoso_Digital_Implem_XL' (main version: 17.1, alternate version: 17.1) checkout failed.
Cannot obtain 'Genus_Synthesis' license.
Failed on application-specific initialization
Abnormal exit.
最佳答案
查看完整内容
不要装在这么新的Ubuntu上, 我在centos7上装过这个,用论坛上的1patch处理过呼可以用。1patch论坛搜索一下。
发表于 2022-10-13 05:27:41 | 显示全部楼层
 楼主| 发表于 2022-10-13 05:38:46 | 显示全部楼层
这是我发的另一个求 Innovus license 的帖子,如果哪位大佬有的话也可以去那里发一下:https://bbs.eetop.cn/thread-936872-1-1.html
发表于 2022-10-13 11:09:14 | 显示全部楼层
Cadence recommends RedHat (CentOS)7 or  SUSE 12 OS.
发表于 2022-10-13 11:46:10 | 显示全部楼层
顶一下
 楼主| 发表于 2022-10-13 23:45:14 | 显示全部楼层
zjz0319 发表于 2022-10-13 09:35
不要装在这么新的Ubuntu上, 我在centos7上装过这个,用论坛上的1patch处理过呼可以用。1patch论坛搜索一下 ...
因为要拿Genus对接机器学习的算法,只能用Ubuntu了,CentOS7上好多库都没有我先拿1patch试试看吧
====更新====
我拿V0.3的1patch试了一下,现在可以正常运行Genus了,1patch帖子链接:https://bbs.eetop.cn/thread-896342-1-1.html
同样的方法用到 Innovus 18.10 就还会报错,说是OA库有问题,和这个帖子里的报错一摸一样:https://bbs.eetop.cn/thread-878222-1-1.html
发表于 2024-5-22 00:40:59 | 显示全部楼层
thanks
GMT+8, 2025-12-21 20:47 , Processed in 0.021506 second(s), 5 queries , Gzip On, Redis On.
