查看: 3253|回复: 2
[求助] cadence ic617安装后无法启动,求助
发表于 2022-10-1 23:04:24 | 显示全部楼层 |阅读模式
root@zxzheng ~]# virtuoso &
[1] 15145
[root@zxzheng ~]# \e Display :0 Error "BadAtom (invalid Atom parameter)"
\e  request 20 error 5 serial 228
*ERROR* (DB-320001): Unable to obtain the 'Cadence(R) Design Framework II' license. Run 'lmstat -f 111' to see license, server, and usage information. For more information, see the sections related to license maintenance in the 'Cadence License Manager' manual.
lmstat -f 111
bash: /opt/mentor/Calibre2015/aoi_cal_2015.2_36.27/bin/lmstat: /lib64/ld-lsb-x86-64.so.3: bad ELF interpreter: No such file or directory
[1]+  Exit 111                virtuoso
以上是命令执行情况,LIC也做了好几遍,结果没啥用,求大神解惑!
 楼主| 发表于 2022-10-1 23:05:13 | 显示全部楼层
笔记本上安装没出现这个问题,台式机就出了,搞不懂啊
发表于 2023-7-31 09:51:44 | 显示全部楼层
解决了吗,同问
GMT+8, 2025-12-26 05:36 , Processed in 0.013321 second(s), 4 queries , Gzip On, Redis On.
