查看: 3272|回复: 7
A Simplified Single Correlator Rake Receiver for CDMA Communications
发表于 2008-1-9 21:39:42 | 显示全部楼层 |阅读模式
CDMA Communications
K. Murali Krishna, Abhijit Mitra and Cemal Ardil
Abstract—This paper presents a single correlator RAKE receiver
for direct sequence code division multiple access (DS-CDMA) systems.
In conventional RAKE receivers, multiple correlators are used
to despread the multipath signals and then to align and combine those
signals in a later stage before making a bit decision. The simplified
receiver structure presented here uses a single correlator and single
code sequence generator to recover the multipaths. Modified Walsh-
Hadamard codes are used here for data spreading that provides
better uncorrelation properties for the multipath signals. The main
advantage of this receiver structure is that it requires only a single
correlator and a code generator in contrary to the conventional RAKE
receiver concept with multiple correlators. It is shown in results that
the proposed receiver achieves better bit error rates in comparison
with the conventional one for more than one multipaths.
INTERNATIONAL JOURNAL OF INFORMATION TECHNOLOGY VOLUME 2 NUMBER 4 2005 ISSN 1305-2403
A Simplified Single Correlator Rake Receiver.pdf
368.9 KB, 下载次数: 47 , 下载积分: 资产 -2 信元, 下载支出 2 信元
发表于 2008-9-12 16:03:35 | 显示全部楼层
tks a lot
发表于 2008-10-12 17:52:12 | 显示全部楼层
thanks very much for your sharing
发表于 2009-4-6 18:19:06 | 显示全部楼层
好文章,支持
发表于 2009-5-21 16:16:50 | 显示全部楼层
好东西,谢谢啦
发表于 2009-6-3 17:07:10 | 显示全部楼层
下来看看  谢谢了
发表于 2010-12-20 22:24:49 | 显示全部楼层
好东东啊,强烈支持啊!!!
发表于 2011-12-2 19:02:51 | 显示全部楼层
好东西 谢谢了哈
GMT+8, 2025-12-26 18:16 , Processed in 0.025210 second(s), 7 queries , Gzip On, Redis On.
