查看: 2714|回复: 1
Assura LVS报错
发表于 2022-9-9 20:47:15 | 显示全部楼层 |阅读模式
悬赏200资产未解决
Starting dfIIToVdb...
/home/soft/cadence/installs/ASSURA41/tools/assura/bin/64bit/dfIIToVdb: symbol lookup error: /home/soft/cadence/installs/ASSURA41/tools/assura/bin/64bit/dfIIToVdb: undefined symbol: _ZTIN12OpenAccess_431oaExceptionFromObserverObserverE
*WARNING* Translation abnormally terminated!
*WARNING* aveng exit with bad status
*WARNING* Status 256
*WARNING* Assura execution terminated
使用刚安装的assura616,LVS会报错,DRC可以正常运行。
环境变量设置如下:
export CADHOME_A=/home/soft/cadence/installs
export ASSURAHOME=$CADHOME_A/ASSURA41
export PATH=${PATH}ASSURAHOME/binASSURAHOME/tools/binASSURAHOME/tools/assura/bin
发表于 2022-9-10 09:51:18 | 显示全部楼层
ASSURA和IC61的版本需要匹配的,你用的是哪个版本的IC6?据我所知,没有Assura616版本,只有416,对应的是618;
GMT+8, 2025-12-21 12:30 , Processed in 0.014270 second(s), 5 queries , Gzip On, Redis On.
