查看: 2008|回复: 0
hspice2016 win版本使用 verilog-A的问题
发表于 2022-9-2 16:30:15 | 显示全部楼层 |阅读模式
  1. **error** *pvaE* 1. Contact system admin to install /usr/lib/crti.o
  2. **error** *pvaE*       If error message '/usr/bin/ld: crti.o: No such file or directory'
  3. **error** *pvaE*       collect2: ld returned 1 exit status in pvaRTL.log
  4. **error** *pvaE* 2. Run 64-bit platform or contact system admin to install /usr/include/gnu/stubs-32.h
  5. **error** *pvaE*       If error message '/usr/include/gnu/stubs.h:7:27:'
  6. **error** *pvaE*       fatal error: gnu/stubs-32.h: No such file or directory compilation terminated.
  7. **error** *pvaE*       make: *** [all] Error 1
  8. **error** *pvaE* 3. Rerun with 'setenv PVA_GCC_FLAGS_O0 1 or setenv PVA_GCC_FLAGS_G 1'
  9. **error** *pvaE*       If error message 'gcc: Internal error: Segmentation fault (program cc1)', or
  10. **error** *pvaE*                        'gcc: Internal error: CPU time limit exceeded (program cc1)'
  11. **error** *pvaE* If error messages do not show, please contact Synopsys, Inc. technical support center.
    复制代码
请问遇到这种问题怎么解决呢?我看在linux系统上有人解决了,链接如下 https://bbs.eetop.cn/thread-581550-1-1.html,但是不知道win系统如何解决,有没有大佬愿意指导我一下呀
GMT+8, 2025-12-22 04:46 , Processed in 0.015221 second(s), 6 queries , Gzip On, Redis On.
