查看: 4371|回复: 15
[资料] TI Power Supply Design Seminar
发表于 2022-8-31 10:57:36 | 显示全部楼层 |阅读模式
    100_Practical Magnetic Design  Inductors and Coupled Inductors (Article).pdf
    101_Practical Magnetic Design  Inductors and Coupled Inductors (Presentation).pdf
    102_Design and Optimization of a High-Performance LLC Converter (Article).pdf
    103_Design and Optimization of a High-Performance LLC Converter (Presentation).pdf
    104_Accelerating Power-Supply Compliance to Specification (Article).pdf
    105_Description  Accelerating Power-Supply Compliance to Specification (Present.).pdf
    106_Advanced Digital Controls Improve PFC Performance (Article).pdf
    107_Advanced Digital Controls Improve PFC Performance (Presentation).pdf
    108_Choosing the Right Fixed Frequency Buck Regulator Control Strategy.pdf
    109_Choosing the Right Fixed Frequency Buck Regulator Control Strategy (PPT).pdf
    10_Seminar 500 DRA - The Right-Half-Plane Zero - A Simplified Explanation.pdf
    110_Choosing the Right Variable Frequency Buck Regulator Control Strategy.pdf
    111_Choosing the Right Variable Frequency Buck Regulator Control Strategy (PPT).pdf
    112_Examining Wireless Power Transfer.pdf
    113_Examining Wireless Power Transfer (PPT).pdf
    114_Under the Hood of a Multiphase Synchronous Rectified Boost Converter.pdf
    115_Under the Hood of a Multiphase Synchronous Rectified Boost Converter (PPT).pdf
    116_Control Challenges for Low Power AC DC Converters.pdf
    117_Control Challenges for Low Power AC DC Converters (PPT).pdf
    118_GaN FET-Based CCM Totem-Pole Bridgeless PFC.pdf
    119_GaN FET-Based CCM Totem-Pole Bridgeless PFC (PPT).pdf
    11_Seminar 600 Topic 1 - Resonant Mode Converter Topologies.pdf
    120_LLC Converter Small Signal Modeling.pdf
    121_LLC Converter Small Signal Modeling (PPT).pdf
    122_Design of a high-frequency series capacitor buck converter.pdf
    123_Design of a high-frequency series capacitor buck converter (PPT).pdf
    124_Flyback transformer design considerations for efficiency and EMI.pdf
    125_Flyback transformer design considerations for efficiency and EMI (PPT).pdf
    126_Switch-mode power converter compensatin made easy.pdf
    127_Switch-mode power converter compensation made easy (PPT).pdf
    128_Bi-directional DC DC converter topology comparison and design.pdf
    129_Bi-directional DC DC converter topology comparison and design (PPT).pdf
    12_Seminar 600 Topic 6 - High Power Factor Preregulator for Off-Line Power Supplies.pdf
    130_Applying SiC and GaN to high-frequency power.pdf
    131_Applying SiC and GaN to high-frequency power (PPT).pdf
    132_Under the hood of a non-inverting buck-boost DC DC converter.pdf
    133_Under the hood of a non-inverting buck-boost DC DC converter (PPT).pdf
    134_Design review of a 2-kW parallelable power supply module.pdf
    135_Design review of a 2-kW parallelable power supply module (PPT).pdf
    136_2016 PSDS Demo Presentation  Introduction to Isolated Topologies.pdf
    137_2016 PSDS Demo Presentation  Power Systems- Design Tools.pdf
    138_2016 PSDS Demo Presentation  Seven things to know about PMBus .pdf
    139_2016 PSDS Demo Presentation  Introduction to USB Type-C & Power Delivery .pdf
    13_Seminar 700 Topic 2 - Isolating the Control Loop.pdf
    140_2016 PSDS Demo Presentation  Design review of 350 W CCM PFC + LLC  Module.pdf
    141_2016 PSDS Demo Presentation  Designing Low-EMI Pwr Converters for Ind & Aut Sys.pdf
    142_Survey of Resonant Converter Topologies.pdf
    143_Survey of Resonant Converter Topologies PPT.pdf
    144_Control and Design Challenges for Synchronous Rectifiers.pdf
    145_Control and Design Challenges for Synchronous Rectifiers PPT.pdf
    146_Comparison of GaN- and Silicon FET-Based Active Clamp Flyback Converters.pdf
    147_Comparison of GaN- and Silicon FET-Based Active Clamp Flyback Converters PPT.pdf
    148_Power Solutions for Class-D Audio Amplifiers.pdf
    149_Power Solutions for Class-D Audio Amplifiers PPT.pdf
    14_Seminar 700 Topic 5 - Average Current Mode Control of Switching Power Supplies.pdf
    150_Common Mistakes in DC DC Converters and How to Fix Them.pdf
    151_Common Mistakes in DC DC Converters and How to Fix Them PPT.pdf
    152_Considerations for Measuring Loop Gain in Power Supplies.pdf
    153_Considerations for Measuring Loop Gain in Power Supplies PPT.pdf
    154_Power-Conversion Techniques for Complying with Automotive Emissions Requirements.pdf
    155_Power Factor Correction (PFC) Circuit Basics.pdf
    156_Voltage Regulator Design and Optimization for High-Current, Fast-Slew-Rate Load .pdf
    157_Common Mistakes in Flyback Power Supplies and How to Fix Them.pdf
    158_Designing a High Power Bidirectional AC DC Power Supply Using SiC FETs.pdf
    159_Practical EMI Considerations for Low-Power AC DC Supplies.pdf
    15_Seminar 700 Topic 7 - Optimizing a High Power Factor Switching Preregulator.pdf
    160_Power-Conversion Techniques for Complying with Auto. Emissions Requirements PPT.pdf
    161_Power Factor Correction (PFC) Circuit Basics PPT.pdf
    162_Voltage Reg. Design and Optimization for High-Current, Fast-Slew-Rate Load PPT .pdf
    163_Common Mistakes in Flyback Power Supplies and How to Fix Them PPT.pdf
    164_ Designing a High Power Bidirectional AC DC Power Supply Using SiC FETs PPT.pdf
    165_ Practical EMI Considerations for Low-Power AC DC Supplies PPT.pdf
    166_Isolated gate-driver bias-supply design considerations PPT.pdf
    167_A supercapacitor and battery backup power-supply design PPT.pdf
    168_Advanced power-converter features to reduce EMI PPT.pdf
    169_Low-noise and low-ripple techniques for a supply without an LDO PPT.pdf
    16_Seminar 800 Topic 2 - Load Sharing With Paralleled Power Supplies.pdf
    170_Optimizing GaN-based high-voltage, high-power designs PPT.pdf
    171_Common mistakes in power-supply layouts and how to avoid them PPT.pdf
    172_Common Mistakes in Power-Supply Layouts and How to Avoid Them.pdf
    173_Advanced Power-Converter Features for Reducing EMI.pdf
    174_Low-Noise and Low-Ripple Techniques for a Supply Without an LDO (Rev. A).pdf
    175_A Super Capacitor and Battery Backup Power-Supply Design.pdf
    176_Optimizing GaN-Based High-Voltage, High-Power Designs.pdf
    17_ Seminar 800 Topic 5 - Fixed-Frequency Resonant-Switched PWM .pdf
    18_Seminar 800 Topic 6 - Considerations in MOSFET, IGBT and MCT Gate Drive Circuits.pdf
    19_ Seminar 900 Topic 1 - Distributed Power Systems .pdf
    1_Seminar 100 Topic 4 - Design Review  250-W Off-Line Forward Converter.pdf
    20_ Seminar 900 Topic 2 - Snubber Circuits .pdf
    21_ Seminar 900 Topic 3 - Designing a Power Converter .pdf
    22_ Seminar 900 Topic 4 - Design Review  Power Converter .pdf
    23_ Seminar 1000 Topic 1 - Power Factor Correction Circuit .pdf
    24_ Seminar 1000 Topic 3 - Active Clamp and Reset Technique .pdf
    25_Seminar 1100 Topic 1 - Fueling Megaprocessors; Empowering Dynamic Energy Mgmt.pdf
    26_ Seminar 1100 Topic 2 - Design Review  DC-DC Converter .pdf
    27_ Seminar 1100 Topic 3 - Consideration for Active Clamp and Reset .pdf
    28_Seminar 1100 Topic 5 - Control Loop Cookbook.pdf
    29_Seminar 1200 Topic 1 - Current-Sensing Solutions for Power-Supply Designers.pdf
    2_Seminar 100 DRA 2 - Line Input Conversion and Input Filter Capacitor Selection.pdf
    30_Seminar 1200 Topic 5 - Unique Four-Quadrant Flyback Converter.pdf
    31_Seminar 1200 Topic 6 - 140-W Multiple-Output High-Density DC DC Converter.pdf
    32_Seminar 1300 Topic 1 - Unique Cascaded Power Converter Topology.pdf
    33_Seminar 1300 Topic 2 - Hot Swap Power Management.pdf
    34_Seminar 1300 App A1 - Frequency Response Measurement for Switching Power.pdf
    35_Seminar 1300 App A2 - A More Accurate Current-Mode Model.pdf
    36_Unitrode Power Supply Seminar Magnetics  Workbook.pdf
    37_Seminar 1400 Topic 4 High-Efficiency Regulated Charge Pumps for High-Current App.pdf
    38_Seminar 1400 Topic 5 Designing Stable Control Loops.pdf
    39_Deriving the Equivalent Circuit from Magnetic Device Properties.pdf
    3_Seminar 300 Topic 1 - Switching Power Supply Topology Review.pdf
    40_Effects of Leakage Inductance on Switching Power Supply Performance.pdf
    41_How to Design a Transformer with Fractional Turns.pdf
    42_2003 Power Seminar - Electromagnetic Compatibility in Switchmode Power Supplies.pdf
    43_2003 Power Seminar - Designing High-Power Factor Off-Line Power Supplies.pdf
    44_2003 Power Seminar - High-Efficiency With a Multi-Output CCM Flyback Supply.pdf
    45_2003 Power Seminar - Transformer and Inductor Design.pdf
    46_2003 Power Seminar - Under the Hood of Low-Voltage DC DC Converters.pdf
    47_2003 Power Seminar - Paralleling Power.pdf
    48_SEM1600 Topic 1  Safety Considerations in Power Supply Design.pdf
    49_SEM1600 Topic 2  Sequencing Power Supplies in Multiple Voltage Rail Environments.pdf
    4_None.pdf
    50_SEM1600 Topic 3  Step-by-Step Approach to AC Line-Powered Converters.pdf
    51_SEM1600 Topic 4  Constructing Your Power Supply – Layout Considerations.pdf
    52_SEM1600 Topic 5  Interleaving Contributes Unique Benefits to Forward and Flyback.pdf
    53_SEM1600 Topic 7  Compensating DC DC Converters With Ceramic Output Capacitors.pdf
    54_Under the Hood of Flyback SMPS Designs PPT Presentation.pdf
    55_Incorporating Active-Clamp Technology to Maximize Efficiency PPT Presentation.pdf
    56_Designing an LLC Resonant Half-Bridge Power Converter PPT Presentation.pdf
    57_Power Factor Correction Using the Buck Topology PPT Presentation.pdf
    58_Dual Half-Bridge DC DC Converter with Wide-Range ZVS PPT Presentation.pdf
    59_Designing a Solar-Cell-Driven LED Outdoor Lighting System PPT Presentation.pdf
    5_Seminar 400 Topic 1 - Current-Mode Control of Switching Power Supplies.pdf
    60_Under the Hood of Flyback SMPS Designs Article.pdf
    61_Incorporating Active-Clamp Technology to Maximize Efficiency Article.pdf
    62_Designing an LLC Resonant Half-Bridge Power Converter Article.pdf
    63_Power Factor Correction Using the Buck Topology Article.pdf
    64_Designing Magnetic Components for Optimum Performance Article.pdf
    65_Dual Half-Bridge DC DC Converter with Wide-Range ZVS Article.pdf
    66_Designing a Solar-Cell-Driven LED Outdoor Lighting System Article.pdf
    67_High Power Factor and High Efficiency-You Can Have Both.pdf
    68_Understanding Noise-Spreading Techniques & their Effects in Switch Mode Power .pdf
    69_Under the Hood of a DC DC Boost Converter.pdf
    6_Seminar 400 Topic 6 - Design Review  150-W Current-Mode Flyback.pdf
    70_Improving System Efficiency w a New Intermediate-Bus Architecture.pdf
    71_High-Voltage Energy Storage  The Key to Efficient Holdup.pdf
    72_Using PMBus(tm) for Improved System-Level Power Mgmt.pdf
    73_Applying Digital Technology to PWM Control-Loop Designs.pdf
    74_Improving Power Supply Efficiency-The Global Perspective.pdf
    75_Feedback  Fast Lane-Modeling Extending Current-Mode Cntrl in High Freq  Conv. .pdf
    76_Designing Planar Magnetics.pdf
    77_An Interleaving PFC Pre-Regulator for High-Power Converters.pdf
    78_Software Design for Digital Power Programming 101 for Analog Designers.pdf
    79_Designing a Digital Telecom Rectifier.pdf
    7_Seminar 500 Topic 1 - Practical Considerations in Current-Mode Power Supplies.pdf
    80_High Power Factor and High Efficiency-You Can Have Both (PP).pdf
    81_Understanding Noise-Spreading Techniques & their Effects in Switch Mode (PP) .pdf
    82_Under the Hood of a DC DC Boost Converter (PP).pdf
    83_Improving System Efficiency w a New Intermediate-Bus Arch(PP).pdf
    84_High-Voltage Energy Storage  The Key to Efficient Holdup (PP).pdf
    85_Using PMBus(tm) for Improved System-Level Power Mgmt (PP).pdf
    86_Applying Digital Technology to PWM Control-Loop Designs (PP).pdf
    87_Improving Power Supply Efficiency-The Global Perspective - PP.pdf
    88_Green-Mode Power by the Milli-Watt - PP.pdf
    89_Feedback  Fast Lane-Mod Extending Curr-Mode Cntrl in High Freq  Conv. - PP .pdf
    8_Seminar 500 Topic 5 - Coupled Filter Inductors in Buck Regulators (Rev. A).pdf
    90_Designing Planar Magnetics - PP.pdf
    91_An Interleaving PFC Pre-Regulator for High-Power Converters-PP.pdf
    92_Software Des. for Digital Power Programming 101 for Analog Designers-PP.pdf
    93_Designing a Digital Telecom Rectifier - PP.pdf
    94_Input EMI Filter Design for Offline Phase-Dimmable LED Power Supplies.pdf
    95_Input EMI Filter Design for Offline Phase-Dimmable LED (Presentation).pdf
    96_A Design Review of a Full-Featured 350W Offline Power Converter (Article).pdf
    97_Description  A Design Review of a Full-Featured 350W Offline Power Converter .pdf
    98_Exposing the Inner Behavior of a Quasi-Resonant Flyback Converter (Article).pdf
    99_Exposing the Inner Behavior of a Quasi-Resonant Flyback Converter (Presentation).pdf
    9_Seminar 500 Topic 6 - 300-W 300-kHz Current-Mode Half-Bridge Converter.pdf
TI Power Supply Design Seminar.txt
234 Bytes, 下载次数: 88 , 下载积分: 资产 -2 信元, 下载支出 2 信元
售价: 5 信元资产  [记录]
发表于 2022-9-1 09:42:29 | 显示全部楼层
下载看看
发表于 2022-9-1 10:15:50 | 显示全部楼层
看上去很不错
发表于 2022-9-1 10:18:23 | 显示全部楼层
文件怎么获取?
发表于 2022-9-1 11:06:36 | 显示全部楼层
不错,感谢分享。
发表于 2022-9-1 11:36:13 | 显示全部楼层
发表于 2022-9-21 12:15:16 | 显示全部楼层
能不能百度网盘?
发表于 2022-9-21 13:16:33 | 显示全部楼层
thanks
发表于 2023-10-13 18:18:42 | 显示全部楼层
文件失效了
发表于 2023-10-14 11:49:18 | 显示全部楼层
thanks
GMT+8, 2025-12-18 06:19 , Processed in 0.025216 second(s), 6 queries , Gzip On, Redis On.
