查看: 2825|回复: 4
EMPIRE XPU 8.2.0 (2023 Version) with Full License and Tutorials
发表于 2022-7-26 17:57:07 | 显示全部楼层 |阅读模式
EMPIRE XP 8.2.0 (2023 Version) with Full License and Complete Tutorial Examples
EMPIRE XPU is a 3D time domain EM modeling tool for Antennas, Microwave Circuits, EM Chip design and much more. The IMST innovative & proprietary XPU technology is a smart implementation of the Finite Difference Time Domain (FDTD) algorithm on modern CPU architectures. It can drastically reduce simulation times while (in contrast to GPU solutions) maintaining full access to the available main memory. Hardware costs can be drastically reduced as no expensive GPUs are needed.
  • Extremely fast and highly memory efficient solver using IMST proprietary XPU technology
  • Highest performance at all scales with full main memory support (more then 2TB on modern workstations)
  • Just-in-time code generation and caching reduce required memory by 50%
  • Interoperability with all common 3D CAD data, layout formats and vendor simulation projects
  • Intuitive 3D Design Editor with fully integrated multi-layer designer
Modern cars include many antennas and radar sensors for communication and safety. Designing antennas for such systems is quite challenging and can be done very efficient with EMPIRE XPU.
  • Performance analysis of radar antenna arrays including feed network and environment (radome, painted bumper, chassis)
  • Car-to-Car communication including multi-path propagation
  • Near- and far-field prediction of antennas mounted on vehicle
  • Dosimetric assessment of near fields in human bodies (SAR, Power Density, Fields)
  • Wireless power transfer analysis
Efficiency
The unique acceleration technique inside EMPIRE XPU enables fast and efficient FDTD simulations on modern CPUs. A smart algorithm calculates multiple time steps in the cache memory of the CPU. This increases the simulation speed drastically as the simulation speed is no longer limited by the main memory interface. The whole RAM memory of the PC is fast accessible for the EM simulation.
  • Just-in-time compilation and memory re-usage
  • Smart exploitation and full parallel usage of cores, caches and CPUs
If you are interested in the full licensed software  IMST EMPIRE XPU 8.2.0  with full feature license and tutorials, then do well to contact  fast.forever24@gmail.com
发表于 2023-10-12 15:47:06 | 显示全部楼层
分享一下
发表于 2023-10-12 22:18:39 | 显示全部楼层
thanks
发表于 2023-10-12 22:27:53 | 显示全部楼层
下载地址在哪里
发表于 2025-1-12 22:04:55 | 显示全部楼层
各位大佬,能提供个下载地址么?感激不尽!
GMT+8, 2025-12-23 12:16 , Processed in 0.024213 second(s), 4 queries , Gzip On, Redis On.
