查看: 2536|回复: 0
[求助] AMS 仿真错误ERROR (VLOGNET-44): Unable to open the file '/home/IC/....ams/config/netlist/hdlfileDir/cds_globals.v
发表于 2022-7-24 01:41:20 | 显示全部楼层 |阅读模式
显示打不开/cds_globals.v
ERROR (VLOGNET-44): Unable to open the file '/home/IC/study/test1_2022_7_22/dac_8bit_test_1_run/.tempProjectDir/dac_8bit_test_1/ams/config/netlist/hdlfileDir/cds_globals.v' for writing the global signals. Either the
file path is invalid or you do not have permissions to write to this file.
Correct the file path or the file permissions and re-netlist.
Traverse Config libAC8bit_AMS cell:dac_8bit_test_1 view:config
End netlisting Jul 24 01:59:59 2022
ERROR (OSSHNL-514): Netlist generation failed because of the errors reported above. The netlist might not have been generated at all, or the generated netlist could be corrupt. Fix the reported errors and regenerate the netlist.
ERROR (AMS-1247): AMS OSSN netlisting has failed.
Check Simulation->Output Log->Netlister Log for errors.
Correct your design and netlist again.
      ...unsuccessful.
可是 我 netlist 文件夹下面 压根没有 hdlfileDir这个子文件夹   请问这个路径是在哪可以设置吗
搞了两天没找到
求助
GMT+8, 2025-12-23 21:17 , Processed in 0.013958 second(s), 5 queries , Gzip On, Redis On.
