查看: 3172|回复: 3
[原创] CDB转OA
发表于 2022-6-2 17:24:51 | 显示全部楼层 |阅读模式
Virtuoso Framework License (111) was checked out successfully. Total checkout time was 0.14s.
ERROR   (CDBOA-107): You cannot run the translator in the same directory as the
                     CDBA cds.lib file. Doing so would add OpenAccess library
                     definitions to the CDBA cds.lib file, which is not
                     permitted. Run the translator from a different directory.
这个错误是为啥?
 楼主| 发表于 2022-6-2 18:56:11 | 显示全部楼层
解决了
发表于 2023-2-21 19:34:52 | 显示全部楼层
请问楼主是如何解决的
发表于 2023-3-15 17:13:33 | 显示全部楼层
150分的苗子 发表于 2023-2-21 19:34
请问楼主是如何解决的
先把PathEditor 原来的51库删掉,再转换.
GMT+8, 2025-12-19 20:46 , Processed in 0.050466 second(s), 4 queries , Gzip On, Redis On.
