查看: 2648|回复: 6
[原创] 求助,怎么让振荡器,电荷泵,运放这三个模块进行联合AC仿真?
发表于 2022-5-29 09:13:35 | 显示全部楼层 |阅读模式
就是振荡器驱动电荷泵,在一定时间稳定(比如1ms),再使电荷泵的输出供给运放作为电源电压,再仿真运放的AC,就是先tran仿真一定时间再进行AC仿真,这种仿真操作怎么设置啊?求大佬们教教我
发表于 2022-5-29 10:56:41 | 显示全部楼层
设置initial state?没整过这种玩法orz
发表于 2022-5-29 11:10:02 | 显示全部楼层
在Tran设置的option里有一个
------需要设置ac的类型和ac开始验证的时间点
发表于 2022-5-29 11:11:28 | 显示全部楼层
ADE里有个收敛设置的选项 ---> initial condition
 楼主| 发表于 2022-5-29 14:28:24 | 显示全部楼层
image.png 大佬,里面原始条件只有设置节点电压啊?
发表于 2022-5-29 21:53:30 | 显示全部楼层
pss+pac/pstb仿真不行么?
发表于 2022-5-30 14:51:18 | 显示全部楼层
you can refer to "Spectre Circuit Simulator and Accelerated Parallel Simulator User Guide"
Performing Small-Signal Analyses during a Transient Analysis
You can perform an AC and/or noise analysis at specific times during a transient analysis. The
Spectre circuit simulator stops the transient analysis at the specified times, saves operating
point information, and performs the AC and/or noise analysis.
This type of simulation is useful when you want to run an AC analysis after getting past
specific start-up behavior, or when there is more than one point along the transient run that
can be thought of as steady-state.
The syntax for performing a small-signal analysis during transient analysis is:
Name tran stop=stop actimes=time acnames=name
Where:
Name The name of the transient analysis
stop The time at which the transient analysis is to be put on hold.
actimes The time points at which the analyses specified by acnames are
performed.
acnames The names of the analyses to be performed at each time point in the
actimes array. Allowed child analyses are: ac, noise, sp, stb, or
xf.
GMT+8, 2025-12-24 19:49 , Processed in 0.019493 second(s), 4 queries , Gzip On, Redis On.
