查看: 2386|回复: 0
[求助] fm upf
发表于 2022-5-25 17:24:44 | 显示全部楼层 |阅读模式
fm的时候 ,网表中去除了VNW  VPW的 bias pg。但是db中有定义 VNW 和VPW .导致fm的时候。报 X sources are objects in the implementation design that are the source of unknown  logic  values that propagate  to failing compare points 。the most common types are undriven的。我设置了 set_dont_verify  但是还是有这个错。请教下 这个怎么解决呢  谢谢了
GMT+8, 2025-12-23 20:41 , Processed in 0.010869 second(s), 3 queries , Gzip On, Redis On.
