楼主: wmfdavid
tsuprem2004.09的license!
发表于 2008-7-21 18:04:07 | 显示全部楼层
xiexie LZ
发表于 2008-7-23 13:41:08 | 显示全部楼层
Installation of the software.
The software works great. Thank LZ.
But in order to install this package, you also need to download the synopsys installer V1.3 here:
http://www.eetop.cn/bbs/viewthread.php?tid=93468&extra=&highlight=synopsys%2Binstaller&page=1
The basic procedure is simple:
1. install Redhat 7.2 if you don't have.
Here I have difficulty to do that on my core2duo machine, since Redhat 7.2 is so old. Fortunately, we can download
and install vmware server 1.06 from here:
http://www.vmware.com/products/server/
You need to register to get a free serial number.
After that, you can install redhat 7.2 on it.
Install "VMware tools" to install virtual video adapter for Xwindows. Please google for details.
2. Unpack the installer, common, linux files:
zcat installer_v1.3.tar.Z | tar xvf -
tar -xvf taurus_tsuprem4_vW-2004.09-SP1_common.tar
tar -xvf taurus_tsuprem4_vW-2004.09-SP1_linux.tar
3. In Xwindows(Gnome), run setup.sh.
Follow the instructions.
If there is an problem to uncompress, please check ncompress package.
If not, install ncompress-XXX.rpm and run setup.sh again.
4. run install_license.
Go to the /usr/sysnopsys/W-2004.09-SP1/license_tma diretory run install_license.
It will create a new directory
Copy the license file License.tsuprem2004.09.dat to
and rename it as license.dat
5. Add the path in the startup script.
I use B shell, so I add
PATH=$PATHHOME/bin:/usr/sysnopsys/W-2004.09-SP1/bin
in .bash_profile in my home directory.
Now you are good to go.
A simple example:
comment compensated Si with auto-generated mesh
INITIALIZE BORON=5e16 PHOSPHORUS=1e16
DIFFUSION TEMPERAT=1050 TIME=5 DRYO2
DIFFUSION TEMPERAT=1050 TIME=60 F.O2=1.75 F.H2=2.5
SELECT Z=DOPING
PRINT.1D LAYERS
SELECT Z=LOG10(PHOSPHORUS)
PLOT.1D COLOR=2 RIGHT=1 Bottom=14 top=17
SELECT Z=LOG10(BORON)
PLOT.1D ^AXES ^CLEAR COLOR=4
SELECT Z=LOG10(DOPING)
PLOT.1D ^AXES ^CLEAR COLOR=1 line.typ=2
PLOT.1D COLOR=2 RIGHT=0.5 LEFT=0.1 Bottom=14 top=17
发表于 2008-8-28 10:14:53 | 显示全部楼层
Save Graphs as postscript files
In order to save the graphs as postscript files, you need to set the TMAPLOT_REPLOT=CL/POSTSCRIPT.
In B shell, I add
export TMAPLOT_REPLOT
to .bash_profile.
When you plot multiple graphs, you can use left mouse button click or right mouse button click to switch between these graphs. When you make one graph as the front active one, push "d" button. The tmaplot service will create a .dplt file, which is in postscript format.
Please refer to
http://www-personal.umich.edu/~hailingc/EECS423/Running+Tsuprem4+on+CAEN+-+Tutorial+1.pdf
for detail.
RunningTsuprem4.pdf
585.39 KB, 下载次数: 83 , 下载积分: 资产 -2 信元, 下载支出 2 信元
how to run Tsuprem4
发表于 2008-8-28 21:41:02 | 显示全部楼层
好东西,万分感谢!
发表于 2008-8-30 09:01:29 | 显示全部楼层
一起学习。
发表于 2008-8-30 21:40:25 | 显示全部楼层
It works with redhat 9.0.
发表于 2008-9-22 20:21:23 | 显示全部楼层
灌水实在是一件痛苦的事情啊
发表于 2008-9-22 20:23:01 | 显示全部楼层
太好了!!谢谢分享啊!!
发表于 2008-9-22 20:29:49 | 显示全部楼层
终于下完了!!!真不容易啊
发表于 2008-9-22 20:30:50 | 显示全部楼层
原帖由 hubh 于 2008-8-28 10:14 发表
In B shell, I add
to .bash_profile.
When ...
这个也是好东西啊
GMT+8, 2025-12-30 02:06 , Processed in 0.020825 second(s), 5 queries , Gzip On, Redis On.
