查看: 2831|回复: 7
[求助] current reference circuit
发表于 2022-2-21 17:54:33 | 显示全部楼层 |阅读模式
Please upload the following paper
"A process and temperature compensated current reference circuit in CMOS process"
By Marshnil Dave, Maryam Shojaei Baghini, Dinesh Kumar Sharma
, February 2012, Pages 89-97
Abstract
A novel current reference circuit that compensates for process and temperature variations without any extra trimming is proposed in this paper. Four thousand Monte Carlo simulations show that the maximum % error (deviation from the desired value) in the reference current is ±5.07% considering process variations (die-to-die, wafer-to-wafer and batch-to-batch). Considering process variations and temperature change from 0 °C to 100 °C both, the maximum error in the reference current is±8.56%. The proposed circuit has been fabricated in 180 nm CMOS process. Measurement results on 50 dice at room temperature show that the mean of the proposed reference current is 9.39% away from its designed value. Mean of drain current of a fixed biased MOSFET fabricated in the same run is 35.41% away from its designed value. Measurements at four different temperatures, 27 °C, 50 °C, 75 °C and 100 °C, on these dice show that the maximum error in the reference current is 17% whereas that in the drain current of a fixed biased MOSFET is 126%. In other words, the proposed current reference circuit reduces the maximum error by a factor of 7 (from 126% to 17%) when process and temperature variations both are considered without trimming. With a simple trimming circuit the maximum variation in the reference current is reduced to ±3.17%
发表于 2022-2-21 21:45:35 | 显示全部楼层
查收下,网上找的
A process and temperature compensated current reference circuit in CMOS process.pdf
1.77 MB, 下载次数: 75 , 下载积分: 资产 -2 信元, 下载支出 2 信元
发表于 2022-2-22 17:17:47 | 显示全部楼层
good topic
thank you~
发表于 2022-2-25 20:59:10 | 显示全部楼层
感谢分享!
发表于 2022-2-26 19:08:20 | 显示全部楼层
thanks
发表于 2024-3-28 14:04:35 | 显示全部楼层
thanks
发表于 2024-4-6 22:17:23 | 显示全部楼层
thanks
发表于 2024-4-7 09:40:33 | 显示全部楼层
jiaoda 发表于 2022-2-21 21:45
查收下,网上找的
Good, thanks
GMT+8, 2025-12-26 18:34 , Processed in 0.023308 second(s), 4 queries , Gzip On, Redis On.
