查看: 1826|回复: 2
[求助] "Render_config" on configured component: "dma230_1" failed.
发表于 2022-1-12 10:58:37 | 显示全部楼层 |阅读模式
最近在用ARM的Socrates配置IP的时候出现这个错误,log输出如下:
buildConfiguredComponent: dma230_1
>>> Starting Operation: Build IP Operation
Checking Bundle IP Associations for: arm.com-PrimeCell-dma230-r0p0_s1
No invalid Bundle IP Associations found.
>>> Starting Operation: Validate Configured Component Operation
ValidateOperationReference has not been specified. Nothing to do.
*  Completion status of Validate Configured Component Operation: Done
Completed refresh of the IP catalog entries.
Executing operation: Copy_bundle
Starting Copy_bundle Operation
Starting Process: /bin/cp -f -R /home/dev/Documents/ARM-DMAC/PL230-BU-00000-r0p0-02rel0/shared/logical/pl230_udma/spirit/../../../../ /home/dev/work/dmac230/logical/dma230_1  [workingDir=/home/dev/Documents/ARM-DMAC/PL230-BU-00000-r0p0-02rel0/shared/logical/pl230_udma/spirit] ...
Wait for Process: /bin/cp -f -R /home/dev/Documents/ARM-DMAC/PL230-BU-00000-r0p0-02rel0/shared/logical/pl230_udma/spirit/../../../../ /home/dev/work/dmac230/logical/dma230_1  [workingDir=/home/dev/Documents/ARM-DMAC/PL230-BU-00000-r0p0-02rel0/shared/logical/pl230_udma/spirit] to complete ...
Finished Process: /bin/cp -f -R /home/dev/Documents/ARM-DMAC/PL230-BU-00000-r0p0-02rel0/shared/logical/pl230_udma/spirit/../../../../ /home/dev/work/dmac230/logical/dma230_1  [workingDir=/home/dev/Documents/ARM-DMAC/PL230-BU-00000-r0p0-02rel0/shared/logical/pl230_udma/spirit].
Result of Copy_bundle Operation : OK
Executing operation: ApplyXSLT_config
Starting ApplyXSLT_config Operation
Result of ApplyXSLT_config Operation : OK
Executing operation: Setup_config
Starting Setup_config Operation
Starting Process: /bin/chmod +x /home/dev/work/dmac230/logical/dma230_1/shared/bin/pl230_engine.pl  [workingDir=/home/dev/ARM-Socrates] ...
Wait for Process: /bin/chmod +x /home/dev/work/dmac230/logical/dma230_1/shared/bin/pl230_engine.pl  [workingDir=/home/dev/ARM-Socrates] to complete ...
Finished Process: /bin/chmod +x /home/dev/work/dmac230/logical/dma230_1/shared/bin/pl230_engine.pl  [workingDir=/home/dev/ARM-Socrates].
Result of Setup_config Operation : OK
Executing operation: Render_config
Starting Render_config Operation
Starting Process: /home/dev/ARM-Socrates/etc/thirdparty/perl/perl-5.12.3/bin/perl /home/dev/work/dmac230/logical/dma230_1/shared/bin/pl230_engine.pl -cfg /home/dev/work/dmac230/logical/dma230_1/configuration_data/cfg_file_configured.xml -render  [envSettings=[PERL5LIB=/home/dev/ARM-Socrates/etc/thirdparty/perl/perl-5.12.3/lib/:/home/dev/ARM-Socrates/etc/thirdparty/perl/perl-5.12.3/lib/site_perl/5.12.3/, PL230_SHARED_DIR=/home/dev/work/dmac230/logical/dma230_1/shared, PATH=/home/dev/work/dmac230/logical/dma230_1/shared/bin:/home/dev/ARM-Socrates/etc/thirdparty/perl/perl-5.12.3/bin/:/home/dev/ARM-Socrates/etc/thirdparty/ad_3p_tools/xalan_1_8_0/linux/bin:/usr/local/bin:/usr/local/sbin:/usr/bin:/usr/sbin:/bin:/sbin:/home/dev/.local/bin:/home/dev/bin, PL230_LOGICAL_DIR=/home/dev/work/dmac230/logical/dma230_1/logical, VENDOR_HOME=/home/dev/work/dmac230/logical/dma230_1, PL230_USE_SIM=mti, PL230_DISPATCHER=NONE, PL230_MAIN_SCRIPT_DIR=/home/dev/work/dmac230/logical/dma230_1/shared/bin, PL230_INSTALL_DIR=/home/dev/work/dmac230/logical/dma230_1, PL230_XSL_PARSER=none, PL230_EXECUTE_DIR=/home/dev/work/dmac230/logical/dma230_1, PL230_OS=linux, PL230_MAKE_TOOL=make]] [workingDir=/home/dev/work/dmac230/logical/dma230_1] ...
Wait for Process: /home/dev/ARM-Socrates/etc/thirdparty/perl/perl-5.12.3/bin/perl /home/dev/work/dmac230/logical/dma230_1/shared/bin/pl230_engine.pl -cfg /home/dev/work/dmac230/logical/dma230_1/configuration_data/cfg_file_configured.xml -render  [envSettings=[PERL5LIB=/home/dev/ARM-Socrates/etc/thirdparty/perl/perl-5.12.3/lib/:/home/dev/ARM-Socrates/etc/thirdparty/perl/perl-5.12.3/lib/site_perl/5.12.3/, PL230_SHARED_DIR=/home/dev/work/dmac230/logical/dma230_1/shared, PATH=/home/dev/work/dmac230/logical/dma230_1/shared/bin:/home/dev/ARM-Socrates/etc/thirdparty/perl/perl-5.12.3/bin/:/home/dev/ARM-Socrates/etc/thirdparty/ad_3p_tools/xalan_1_8_0/linux/bin:/usr/local/bin:/usr/local/sbin:/usr/bin:/usr/sbin:/bin:/sbin:/home/dev/.local/bin:/home/dev/bin, PL230_LOGICAL_DIR=/home/dev/work/dmac230/logical/dma230_1/logical, VENDOR_HOME=/home/dev/work/dmac230/logical/dma230_1, PL230_USE_SIM=mti, PL230_DISPATCHER=NONE, PL230_MAIN_SCRIPT_DIR=/home/dev/work/dmac230/logical/dma230_1/shared/bin, PL230_INSTALL_DIR=/home/dev/work/dmac230/logical/dma230_1, PL230_XSL_PARSER=none, PL230_EXECUTE_DIR=/home/dev/work/dmac230/logical/dma230_1, PL230_OS=linux, PL230_MAKE_TOOL=make]] [workingDir=/home/dev/work/dmac230/logical/dma230_1] to complete ...
Died at /home/dev/work/dmac230/logical/dma230_1/shared/bin/pl230_engine.pl line 825, <XML> line 54.
pl230_engine.pl
Finished Parsing Options
Finished Process: /home/dev/ARM-Socrates/etc/thirdparty/perl/perl-5.12.3/bin/perl /home/dev/work/dmac230/logical/dma230_1/shared/bin/pl230_engine.pl -cfg /home/dev/work/dmac230/logical/dma230_1/configuration_data/cfg_file_configured.xml -render  [envSettings=[PERL5LIB=/home/dev/ARM-Socrates/etc/thirdparty/perl/perl-5.12.3/lib/:/home/dev/ARM-Socrates/etc/thirdparty/perl/perl-5.12.3/lib/site_perl/5.12.3/, PL230_SHARED_DIR=/home/dev/work/dmac230/logical/dma230_1/shared, PATH=/home/dev/work/dmac230/logical/dma230_1/shared/bin:/home/dev/ARM-Socrates/etc/thirdparty/perl/perl-5.12.3/bin/:/home/dev/ARM-Socrates/etc/thirdparty/ad_3p_tools/xalan_1_8_0/linux/bin:/usr/local/bin:/usr/local/sbin:/usr/bin:/usr/sbin:/bin:/sbin:/home/dev/.local/bin:/home/dev/bin, PL230_LOGICAL_DIR=/home/dev/work/dmac230/logical/dma230_1/logical, VENDOR_HOME=/home/dev/work/dmac230/logical/dma230_1, PL230_USE_SIM=mti, PL230_DISPATCHER=NONE, PL230_MAIN_SCRIPT_DIR=/home/dev/work/dmac230/logical/dma230_1/shared/bin, PL230_INSTALL_DIR=/home/dev/work/dmac230/logical/dma230_1, PL230_XSL_PARSER=none, PL230_EXECUTE_DIR=/home/dev/work/dmac230/logical/dma230_1, PL230_OS=linux, PL230_MAKE_TOOL=make]] [workingDir=/home/dev/work/dmac230/logical/dma230_1].
Process exited with abnormal exit code 13
Details of the process executed can be found on the console. Process: /home/dev/ARM-Socrates/etc/thirdparty/perl/perl-5.12.3/bin/perl /home/dev/work/dmac230/logical/dma230_1/shared/bin/pl230_engine.pl -cfg /home/dev/work/dmac230/logical/dma230_1/configuration_data/cfg_file_configured.xml -render  [envSettings=[PERL5LIB=/home/dev/ARM-Socrates/etc/thirdparty/perl/perl-5.12.3/lib/:/home/dev/ARM-Socrates/etc/thirdparty/perl/perl-5.12.3/lib/site_perl/5.12.3/, PL230_SHARED_DIR=/home/dev/work/dmac230/logical/dma230_1/shared, PATH=/home/dev/work/dmac230/logical/dma230_1/shared/bin:/home/dev/ARM-Socrates/etc/thirdparty/perl/perl-5.12.3/bin/:/home/dev/ARM-Socrates/etc/thirdparty/ad_3p_tools/xalan_1_8_0/linux/bin:/usr/local/bin:/usr/local/sbin:/usr/bin:/usr/sbin:/bin:/sbin:/home/dev/.local/bin:/home/dev/bin, PL230_LOGICAL_DIR=/home/dev/work/dmac230/logical/dma230_1/logical, VENDOR_HOME=/home/dev/work/dmac230/logical/dma230_1, PL230_USE_SIM=mti, PL230_DISPATCHER=NONE, PL230_MAIN_SCRIPT_DIR=/home/dev/work/dmac230/logical/dma230_1/shared/bin, PL230_INSTALL_DIR=/home/dev/work/dmac230/logical/dma230_1, PL230_XSL_PARSER=none, PL230_EXECUTE_DIR=/home/dev/work/dmac230/logical/dma230_1, PL230_OS=linux, PL230_MAKE_TOOL=make]] [workingDir=/home/dev/work/dmac230/logical/dma230_1] exited with abnormal exit code 13
*  Completion status of Build IP Operation: ERROR
*  Operation: "Render_config" on configured component: "dma230_1" failed.
*  Details of the process executed can be found on the console.
 楼主| 发表于 2023-7-20 15:49:51 | 显示全部楼层
修改破解文件夹的访问权限
发表于 2023-9-27 01:35:52 | 显示全部楼层
大佬,socrates  破解你是用的eetop 里另外一个好兄弟分享的那个软件和license吗?
站长推荐 上一条 /3 下一条
GMT+8, 2025-9-10 12:08 , Processed in 0.011664 second(s), 3 queries , Gzip On, Redis On.
