查看: 2488|回复: 1
[求助] Sigrity T2B环境变量设置问题
发表于 2022-1-11 16:21:33 | 显示全部楼层 |阅读模式
有人知道sigrity t2b的教程中关于设置环境变量的部分应该怎么设置吗,是打开终端输入命令还是在哪个env文件里输入下面的命令呢?
To run this tutorial, ensure that ASI is installed and you have the Spectre simulator set in path.
As Spectre runs on Linux platform, this tutorial too runs on a Linux machine.
In addition, set up the environment as shown below:
setenv MMSIM_HOME <ASI_install_directory>/tools.lnx86
set path = ($MMSIM_HOME/bin $path)
setenv SIGRITY_EDA_DIR <Sigrity_installation_directory>
set path = ($SIGRITY_EDA_DIR/tools/bin $path)
发表于 2025-11-21 17:21:13 | 显示全部楼层
你好,请问这个问题解决了吗,ASI指的是什么呢,都要填哪些软件的路径作为环境变量呢
GMT+8, 2025-12-16 16:14 , Processed in 0.288361 second(s), 4 queries , Gzip On, Redis On.
