查看: 2138|回复: 0
UART
发表于 2021-11-18 22:25:54 | 显示全部楼层 |阅读模式
// Description   : UART接收波特率产生
// Dependencies  :
// Revision 1.4
// Additional Comments:
`timescale 1ns / 1ps
module UART_RXCLK_v1_4#(
    parameter               SYS_FREQ  = 50_000_000          //输入时钟
   ,parameter               UART_BAUD = 115_200             //波特率
    input                   clk                             //输入时钟
   ,input                   rst_n                           //复位信号
   ,input                   rx_en                           //接收波特率使能
   ,output                  rx_clk                          //UART接收时钟
   //本地参数:
    localparam              BAUDCNT   = SYS_FREQ / UART_BAUD; //波特率计数值
    localparam              BAUDCNT16 = BAUDCNT;
    localparam              BAUDCNT1  = BAUDCNT16 / 16;
    localparam              BAUDCNT2  = BAUDCNT16 / 8;
    localparam              BAUDCNT3  = BAUDCNT2  + BAUDCNT1;
    localparam              BAUDCNT4  = BAUDCNT16 / 4;
    localparam              BAUDCNT5  = BAUDCNT4  + BAUDCNT1;
    localparam              BAUDCNT6  = BAUDCNT4  + BAUDCNT2;
    localparam              BAUDCNT7  = BAUDCNT4  + BAUDCNT3;
    localparam              BAUDCNT8  = BAUDCNT16 / 2;
    localparam              BAUDCNT9  = BAUDCNT8  + BAUDCNT1;
    localparam              BAUDCNT10 = BAUDCNT8  + BAUDCNT2;
    localparam              BAUDCNT11 = BAUDCNT8  + BAUDCNT3;
    localparam              BAUDCNT12 = BAUDCNT16 - BAUDCNT4;
    localparam              BAUDCNT13 = BAUDCNT16 - BAUDCNT3;
    localparam              BAUDCNT14 = BAUDCNT16 - BAUDCNT2;
    localparam              BAUDCNT15 = BAUDCNT16 - BAUDCNT1;
    //函数
    function integer clog2(input integer freq);
        integer i;
        begin
            for(i=0;i<32;i=i+1)
                if(freq) clog2 = i + 1;
        end
    endfunction
    //计数
    localparam              C_DW = clog2(BAUDCNT);          //计数器位宽
    reg         [C_DW-1:0]  cnt;                            //波特率分频计数
    always@(posedge clk ) begin
        if(!rst_n)
            cnt <= {C_DW{1'b0}};
        else if(cnt==BAUDCNT-1)
        else if(rx_en)
            cnt <= cnt + 1'b1;
        else
    end
    //接收波特率信号
    reg                     r_rx_clk;                       //UART接收时钟
    assign rx_clk = r_rx_clk;
    always@(posedge clk) begin
        case(cnt)
                BAUDCNT1,BAUDCNT2,BAUDCNT3,BAUDCNT4,BAUDCNT5,BAUDCNT6,BAUDCNT7,BAUDCNT8,
                BAUDCNT9,BAUDCNT10,BAUDCNT11,BAUDCNT12,BAUDCNT13,BAUDCNT14,BAUDCNT15,BAUDCNT16 :
                r_rx_clk <= 1'b1;
            default :
                r_rx_clk <= 1'b0;
        endcase
    end
endmodule
GMT+8, 2025-12-24 08:41 , Processed in 0.011969 second(s), 4 queries , Gzip On, Redis On.
