查看: 7024|回复: 12
Cracked EDA - Be careful !!!
发表于 2021-11-10 00:46:19 | 显示全部楼层 |阅读模式
Hi.
I just have been warned that Cadence software (even if cracked) is collecting information (username, hostname and IP/MAC address) every time you check-out a license and sends this info to Cadence corporate servers.
So if you ever have worked with Cadence EDA while your computer is connected to the internet Cadence Corp. has all the info.
Has anyone else heard about this? My source is very reliable.
Are there ways to block it (except not connecting to the internet ever) ?
发表于 2021-11-10 07:42:50 | 显示全部楼层
snps does the same thing now
发表于 2021-11-10 07:52:57 | 显示全部楼层
yup, Synopsys does the same thing
Don't try the block port number, that doesn't work cause flex is using a floating port!
Also, the latest version is using delayed report submission
report will be sent once a connection is raised
发表于 2021-11-10 08:52:17 | 显示全部楼层
还有什么大型软件不后台收集客户信息?
发表于 2021-11-10 08:58:42 | 显示全部楼层
run in virtual machine, and block the connection of VM.
发表于 2021-11-10 10:09:49 | 显示全部楼层
Do you use firewall to block information ?
发表于 2021-11-10 11:30:36 | 显示全部楼层
个人使用的话,没问题吧
 楼主| 发表于 2021-11-10 15:24:18 | 显示全部楼层
Currently it looks like VM is the best solution.
Do you know where Cadence/Synopsys store this information? Maybe it can be erased once in a while.
发表于 2021-11-10 19:23:54 | 显示全部楼层
run commands to see if connection is there to cadence or other EDA Co.
netstat -lntu
ss -lntu
发表于 2021-11-10 20:00:53 | 显示全部楼层
像Centos之类也不能联网Update了?
GMT+8, 2025-12-25 18:56 , Processed in 0.018969 second(s), 3 queries , Gzip On, Redis On.
