查看: 2760|回复: 2
[求助] 求助各位大神,跑比较器版图lvs时遇到如下错误,无法将电路中调用的子模块与版图对应。
发表于 2021-10-25 21:08:11 | 显示全部楼层 |阅读模式
     错误如下所示,子模块LVS均无错误,放在比较器版图里之后就报错了。
Error:    Different numbers of instances (see below).
LAYOUT CELL NAME:         pcmp2
SOURCE CELL NAME:         pcmp2
INITIAL NUMBERS OF OBJECTS
                Layout    Source         Component Type
Ports:              7         7
Nets:              24        22    *
Instances:         45        17    *    MN (4 pins)
                    56        19    *    MP (4 pins)
                     6         0    *    D (2 pins)
Total Inst:       107        36
NUMBERS OF OBJECTS AFTER TRANSFORMATION
Ports:              7         7
Nets:              13        13
Instances:          2         2         MN (4 pins)
                     6         6         MP (4 pins)
                     1         1         SMP2 (4 pins)
                     1         3    *    _invv (4 pins)
                     0         2    *    _invx4v (4 pins)
                     2         0    *    _invx5v (4 pins)
                     2         2         _smn2v (4 pins)
Total Inst:        14        16
       * = Number of objects in layout different from number in source.
                                 INCORRECT OBJECTS
LEGEND:
  ne  = Naming Error (same layout name found in source
        circuit, but object was matched otherwise).
                                 INCORRECT INSTANCES
DISC#  LAYOUT NAME                                               SOURCE NAME
  1    (_invx5v)                                                 ** missing injected instance **
       Devices:
         X4/M1(10.725,-45.215)  MP(P18)
         X4/M0(10.415,-48.195)  MN(N18)
         X41/M16(12.785,-56.540)  MP(P18)
         X41/M1(15.365,-56.540)  MN(N18)
         X41/M17(12.785,-58.060)  MP(P18)
         X41/M2(15.365,-58.140)  MN(N18)
         X41/M19(12.785,-60.320)  MP(P18)
         X41/M4(15.365,-60.560)  MN(N18)
         X41/M23(12.785,-64.060)  MP(P18)
         X41/M8(15.365,-64.620)  MN(N18)
  2    (_invx5v)                                                 ** missing injected instance **
       Devices:
         X6/M1(24.725,-45.410)  MP(P18)
         X6/M0(25.035,-48.390)  MN(N18)
         X42/M16(22.785,-56.540)  MP(P18)
         X42/M1(20.205,-56.540)  MN(N18)
         X42/M17(22.785,-58.060)  MP(P18)
         X42/M2(20.205,-58.140)  MN(N18)
         X42/M19(22.785,-60.320)  MP(P18)
         X42/M4(20.205,-60.560)  MN(N18)
         X42/M23(22.785,-64.060)  MP(P18)
         X42/M8(20.205,-64.620)  MN(N18)
  3    ** missing injected instance **                           (_invv)
        Devices:
        XI51/MPM0  MP(P18)
        XI51/MNM0  MN(N18)
  4    ** missing injected instance **                           (_invv)
        Devices:
        XI50/MPM0  MP(P18)
        XI50/MNM0  MN(N18)
  5    ** missing injected instance **                           (_invx4v)
        Devices:
        XI58/MPM0  MP(P18)
        XI58/MNM0  MN(N18)
        XI58/MPM2  MP(P18)
        XI58/MNM2  MN(N18)
        XI58/MPM3  MP(P18)
        XI58/MNM3  MN(N18)
        XI58/MPM4  MP(P18)
        XI58/MNM4  MN(N18)
  6    ** missing injected instance **                           (_invx4v)
        Devices:
        XI57/MPM0  MP(P18)
        XI57/MNM0  MN(N18)
        XI57/MPM2  MP(P18)
        XI57/MNM2  MN(N18)
        XI57/MPM3  MP(P18)
        XI57/MNM3  MN(N18)
        XI57/MPM4  MP(P18)
        XI57/MNM4  MN(N18)
                               INFORMATION AND WARNINGS
                  Matched    Matched    Unmatched    Unmatched    Component
                   Layout     Source       Layout       Source    Type
   Ports:               7          7            0            0
   Nets:               13         13            0            0
   Instances:           2          2            0            0    MN(N18)
                        6          6            0            0    MP(P18)
                        1          1            0            0    SMP2
                        1          1            0            2    _invv
                        0          0            0            2    _invx4v
                        0          0            2            0    _invx5v
                        2          2            0            0    _smn2v
   Total Inst:         12         12            2            4
o Statistics:
   6 layout instances were filtered and their pins removed from adjoining nets.
   84 layout mos transistors were reduced to 21.
     63 mos transistors were deleted by parallel reduction.
   2 unused layout mos transistors were deleted.
o Initial Correspondence Points:
   Ports:        AVDD AVSS VIP CLKC VIN VON VOP
发表于 2021-10-26 08:28:35 | 显示全部楼层
光看这些,判断不出哪里的错。
 楼主| 发表于 2021-10-26 11:02:52 | 显示全部楼层
winsm 发表于 2021-10-26 08:28
光看这些,判断不出哪里的错。
感谢回复,我在比较器电路中调用了反相器和反相器链做的buffer,在layoutXL里面点击版图对应的模块会高亮,但是进行LVS之后出现了原理图和版图无法对应的情况。请问还需要哪些信息我整理一下,感谢感谢!
GMT+8, 2025-12-14 22:26 , Processed in 1.126084 second(s), 3 queries , Gzip On, Redis On.
