查看: 2786|回复: 3
qrc打开报错
发表于 2021-10-13 11:14:47 | 显示全部楼层 |阅读模式
打开qrc就报错:*Error* load: error while loading file - “/opt/Mentor//calibre2018/aoi_cal_2018.4_34.26/lib/calibre.skl" at line 129
各位大佬知道是怎么回事么?求解
发表于 2021-10-13 15:07:20 | 显示全部楼层
这个报错跟qrc没有关系,是calibre 集成写的路径不对,编辑cdsinit文件,看看calibre的路径是不是写错了
 楼主| 发表于 2021-10-13 18:43:27 | 显示全部楼层
yuzhijie 发表于 2021-10-13 15:07
这个报错跟qrc没有关系,是calibre 集成写的路径不对,编辑cdsinit文件,看看calibre的路径是不是写错了 ...
; checkCALIBRE_HOME
cal_home=getShellEnvVar("CALIBRE_HOME")
if(cal_home==nil then
   cal_home=getShellEnvVar("MGC_HOME")
    if( cal_home!=nil then
        printf("// CALIBRE_HOMEenvironment variable not set; setting it to value of MGC_HOME\n");
if(cal_home!=nil && isDir(cal_home) && isReadable(cal_home) then
    ; Load calibre.skl or calibre.4.3.skl, notboth!
    ; Load calibre.skl for Cadence versions 4.4and greater
    load(strcat(cal_home"/lib/calibre.skl"))
;;;;Loadcalibre.4.3.skl for Cadence version 4.3
;;;load(strcat(cal_home "/lib/calibre.4.3.skl"))
else
    ; CALIBRE_HOME is not set correctly. Reportthe problem.
    printf("//  Calibre Error: Environment variable ")
    if( cal_home==nil || cal_home==""then
        printf("CALIBRE_HOME is notset.");
    else
        if( !isDir(cal_home) then
            printf("CALIBRE_HOME does notpoint to a directory.");
        else
            if( !isReadable(cal_home) then
                printf("CALIBRE_HOMEpoints to an unreadable directory.");
    printf(" Calibre Skill Interface notloaded.\n")
    ; Display a dialog box message about loadfailure.
    hiDisplayAppDBox(
        ?name           'MGCHOMEErrorDlg
        ?dboxBanner     "Calibre Error"
        ?dboxText       "Calibre Skill Interface notloaded."
        ?dialogType     hicErrorDialog
        ?dialogStyle    'modal
       ?buttonLayout   'Close
这个cdsinit文件对吗?
发表于 2023-6-28 14:45:24 | 显示全部楼层
路径错了,应该是/opt/Mentor/calibre2018/aoi_cal_2018.4_34.26/lib/calibre.skl
您的CALIBRE_HOME得修正一下
GMT+8, 2025-12-20 11:13 , Processed in 0.014577 second(s), 4 queries , Gzip On, Redis On.
