查看: 2837|回复: 4
[原创] 求助:如何安装KEY_FOUNDRY PDK
发表于 2021-10-10 23:07:38 | 显示全部楼层 |阅读模式
安装说明如下:3. Installation procedures
   Just type the following command in the UNIX prompt and follow the instructions.
   The directory where KF_DK_Installer.sh will be executed must contain only PDK set, Library set, Document set files
   downloaded from http://ismart.magnachip.com. (If not, other files will not be installed with error messages.)
   1) First, Before excuting 'KF_DK_Installer.sh' script, you must assign excute permission to the
       'KF_DK_Installer.sh' script using 'chmod' command as below.
      # chmod +x KF_DK_Installer.sh
   2) Next, you can excute KF_DK_Installer.sh script with below option.
      # ./KF_DK_Installer.sh -d PDK_directory [-l Library_directory]
        note : 1. 'KF_DK_Installer.sh' will install KF PDK set files on current directory
                  into the directory that you specified using only '-d' option
               2. it will install KF Library files into the directory specified with '-l' option
                  (if not specified, the library files will be installed into PDK_directory."library" directory)
运行安装包后报错如下:
xxxx:~/project/PDK/PRO$ ./KF_DK_Installer.sh
For Help: KF_DK_Installer.sh  -h (or) KF_DK_Installer.sh -help
Running with Using /bin/tar
- usage: ./KF_DK_Installer.sh
                      -d PDK_directory
                      [-l library_directory]
                      [-m mpdk_file] [-m mpdk_file]
      ex) ./KF_DK_Installer.sh -d KF_DIR [-l library_directory] [-m PDK.mpdk]
- environment requirment:
      gzip     - to be found in path
      unzip    - to be found in path
      dos2unix - to be found in path
      tar      - to be found in path
for additional information, see the README file.
是在运行install.sh的时候哪个命令不对吗?
发表于 2021-10-13 17:43:20 | 显示全部楼层
你在运行安装包时的命令是什么呀?会不会是由于执行./KF_DK_Installer.sh -d PDK_directory命令时,PDK_directory没有写正确?
发表于 2021-10-30 18:11:12 | 显示全部楼层
楼主解决没?我的也是magnachip,不知如何安装
发表于 2022-8-8 14:24:16 | 显示全部楼层
楼主解决没?遇到同样的问题,求助
发表于 2024-7-2 12:03:51 | 显示全部楼层
同问
GMT+8, 2025-9-17 10:57 , Processed in 0.014302 second(s), 4 queries , Gzip On, Redis On.
