查看: 12453|回复: 29
VCS2020不能正常使用?
发表于 2021-10-9 21:25:36 | 显示全部楼层 |阅读模式
出现以下错误,头大了。。。
Command line: ./simv
--- Stack trace follows:
Dumping VCS Annotated Stack:
#0  0x00002aaab3ec0549 in waitpid () from /lib64/libc.so.6
#1  0x00002aaab3e3df62 in do_system () from /lib64/libc.so.6
#2  0x00002aaab3e3e311 in system () from /lib64/libc.so.6
#3  0x00002aaaab6da66b in SNPSle_10ee25eff68cd8461c9146fa1d0b35e87067f3c8015b313e639d2928478c79b3f673f99203bcf8be64600612100082236bffb2007f1e0ef9 () from /Software/Synopsys/Installs/vcs/R-2020.12-SP1/linux64/lib/liberrorinf.so
#4  0x00002aaaab6dc143 in SNPSle_10ee25eff68cd8461c9146fa1d0b35e87067f3c8015b313efba706aab251478fa49e66610e453774633a6c152e7ef778f2202cda681f3d4e () from /Software/Synopsys/Installs/vcs/R-2020.12-SP1/linux64/lib/liberrorinf.so
#5  0x00002aaaab6d4a52 in SNPSle_d35ca1ff70d465c2b9b1a72eee90a50630165806651fae96eee2bdb18305df1f () from /Software/Synopsys/Installs/vcs/R-2020.12-SP1/linux64/lib/liberrorinf.so
#6  0x00002aaaae0e76ab in SNPSle_64133461705005bb725549e2e6fa1b3f () from /Software/Synopsys/Installs/vcs/R-2020.12-SP1/linux64/lib/libvcsnew.so
#7  0x00002aaaadd79209 in SNPSle_82244d58c54c18c70d63edc9becab634 () from /Software/Synopsys/Installs/vcs/R-2020.12-SP1/linux64/lib/libvcsnew.so
#9  0x00002aaaaba6a974 in mem_free () from /Software/Synopsys/Installs/vcs/R-2020.12-SP1/linux64/lib/libsnpsmalloc.so
#10 0x00002aaaaba46145 in snpsCheckFreeFunc () from /Software/Synopsys/Installs/vcs/R-2020.12-SP1/linux64/lib/libsnpsmalloc.so
#11 0x00002aaaadaee2e8 in SNPSle_540905a7b1b27611 () from /Software/Synopsys/Installs/vcs/R-2020.12-SP1/linux64/lib/libvcsnew.so
#12 0x00002aaaadaeec2e in SNPSle_9ff9b2dce8f1fde9 () from /Software/Synopsys/Installs/vcs/R-2020.12-SP1/linux64/lib/libvcsnew.so
#13 0x00002aaaadaeccfc in SNPSle_36c2d46996c96605 () from /Software/Synopsys/Installs/vcs/R-2020.12-SP1/linux64/lib/libvcsnew.so
#14 0x00002aaaadaed1c1 in SNPSle_2c2186f0f2f42415 () from /Software/Synopsys/Installs/vcs/R-2020.12-SP1/linux64/lib/libvcsnew.so
#15 0x00002aaaadaed2d7 in SNPSle_126d17af453e054a () from /Software/Synopsys/Installs/vcs/R-2020.12-SP1/linux64/lib/libvcsnew.so
#16 0x00002aaab3563ea5 in start_thread () from /lib64/libpthread.so.0
#17 0x00002aaab3ef99fd in clone () from /lib64/libc.so.6
#0  0x00002aaab3ec08ed in nanosleep () from /lib64/libc.so.6
#1  0x00002aaab3ec0784 in sleep () from /lib64/libc.so.6
#2  0x00002aaaad87da26 in SNPSle_95ae9cc2e78cc668673c60b8d88c4908 () from /Software/Synopsys/Installs/vcs/R-2020.12-SP1/linux64/lib/libvcsnew.so
#3  0x00002aaaad87dbcd in SNPSle_92de4d0d4cf0d6931bc37e8d42a01d93 () from /Software/Synopsys/Installs/vcs/R-2020.12-SP1/linux64/lib/libvcsnew.so
#4  0x00002aaaad87bf67 in SNPSle_b76ef993ee82b3d58a5cadddbec8b67c () from /Software/Synopsys/Installs/vcs/R-2020.12-SP1/linux64/lib/libvcsnew.so
#5  0x00002aaaad87c235 in SNPSle_f28f24b8c84ac8f6e02e0b03bcd33aa8 () from /Software/Synopsys/Installs/vcs/R-2020.12-SP1/linux64/lib/libvcsnew.so
#6  0x00002aaaad865e04 in SNPSle_5e54eaa1df739f6ed4c1ff24a0986ee6 () from /Software/Synopsys/Installs/vcs/R-2020.12-SP1/linux64/lib/libvcsnew.so
#7  0x00002aaaad86604c in SNPSle_058778405d2a6c04ddd18247ba7f440f () from /Software/Synopsys/Installs/vcs/R-2020.12-SP1/linux64/lib/libvcsnew.so
#8  0x00002aaaad867b82 in SNPSle_e376be325e61b493d6bd988d8077bacc () from /Software/Synopsys/Installs/vcs/R-2020.12-SP1/linux64/lib/libvcsnew.so
#9  0x00002aaaad868bc3 in SNPSle_a10369bdf7c5916ddd6866ce7e2e861c () from /Software/Synopsys/Installs/vcs/R-2020.12-SP1/linux64/lib/libvcsnew.so
#10 0x00002aaaad86bbd5 in SNPSle_00b1acee80c770570cd75f9efbe24cca () from /Software/Synopsys/Installs/vcs/R-2020.12-SP1/linux64/lib/libvcsnew.so
#11 0x00002aaaad861d20 in SNPSle_ba11b1edbd04051f5bb81b1861cdf84a () from /Software/Synopsys/Installs/vcs/R-2020.12-SP1/linux64/lib/libvcsnew.so
#12 0x00002aaaad8523c2 in SNPSle_2e65c0794628fc5af60953149776c29b () from /Software/Synopsys/Installs/vcs/R-2020.12-SP1/linux64/lib/libvcsnew.so
#13 0x00002aaaad84ec74 in SNPSle_541f757be362289a7c9e5618c0ff28327846f8d3cc02839f () from /Software/Synopsys/Installs/vcs/R-2020.12-SP1/linux64/lib/libvcsnew.so
#14 0x00002aaaad8486e8 in SNPSle_c0de1345d5ab80930e06dd2b68f214c3 () from /Software/Synopsys/Installs/vcs/R-2020.12-SP1/linux64/lib/libvcsnew.so
#15 0x00002aaaad8488b2 in SNPSle_25cd5712eacded5ff943afa9a81fcb09 () from /Software/Synopsys/Installs/vcs/R-2020.12-SP1/linux64/lib/libvcsnew.so
#16 0x00002aaaae10a35f in SNPSle_490598bfebcc8e8183ad3550288b1f82 () from /Software/Synopsys/Installs/vcs/R-2020.12-SP1/linux64/lib/libvcsnew.so
#17 0x00002aaaae116260 in SNPSle_490598bfebcc8e81 () from /Software/Synopsys/Installs/vcs/R-2020.12-SP1/linux64/lib/libvcsnew.so
#18 0x0000000000406b73 in main ()
Process VmPeak: 437248 kb, VmSize: 373796 kb
System Free Memory: 492008 kb, System Free Swap: 118665372 kb
No context available
发表于 2021-10-10 10:41:24 | 显示全部楼层
可能是vcs本身崩了(重新编译下,再执行simv试试),或是代码有问题,编译后simv踩内存了(检查代码,比如静态interface里使用了动态数组/队列)
 楼主| 发表于 2021-10-10 17:09:27 | 显示全部楼层
leb925 发表于 2021-10-10 10:41
可能是vcs本身崩了(重新编译下,再执行simv试试),或是代码有问题,编译后simv踩内存了(检查代码,比如 ...
换了不同的版本,也跑了不同的lab,都是这个问题。。。心塞
发表于 2021-10-10 19:26:51 来自手机 | 显示全部楼层
也可能是lic问题
发表于 2021-10-10 23:35:19 | 显示全部楼层
可以看看代码,如果之前正常,就重点看看最近修改的地方
发表于 2021-10-11 13:45:11 | 显示全部楼层
可能scl的问题,我这用2018的scl,2018vcs运行正常,
换了2021的scl破解以后同样vcs编出来的就simv运行报和你一样的错误
刚又试了一下,还是license的问题。
 楼主| 发表于 2021-10-12 09:04:41 | 显示全部楼层
换了2021的scl破解以后同样vcs编出来的就s ...
请问下,License的问题怎么解决呀?
 楼主| 发表于 2021-10-12 09:08:02 | 显示全部楼层
代码用的是官方lab,也没有改动。。。。
发表于 2021-10-12 09:53:05 | 显示全部楼层
静候
发表于 2021-10-13 09:52:45 | 显示全部楼层
我把license里面的一些时间改了就正常了,不知道为什么
GMT+8, 2025-12-24 13:04 , Processed in 0.021565 second(s), 3 queries , Gzip On, Redis On.
