查看: 3547|回复: 3
[求助] 新人求助,仿真过程遇到的error
发表于 2021-10-9 17:00:41 | 显示全部楼层 |阅读模式
Compiling ahdlcmi module library.
Error found by spectre during AHDL read-in.
    ERROR (VACOMP-1008): Cannot compile ahdlcmi module library. Check the log file /home/pitl/simulation/BLDC3/test_opamp4/adexl/results/data/Interactive.14/sharedData/Job6/ahdl/input.ahdlSimDB/bsource_064b50.va.bsource_064b50.ahdlcmi/Linux-64//..//ahdlcmi.out for details. Contact your Cadence Customer Support representative with the netlist, log files, behavioral model files, and any other information that can help identify the problem.
    ERROR (SFE-91): Error when elaborating the instance bsource_064b50. Simulation should be terminated.
Error found by spectre during hierarchy flattening.
    ERROR (SFE-46): "/home/pitl/Desktop/XD9504A/s10hvcsdst60v19.scs" 778: `rs1': An instance of `bsource_064b50' can have at most 0 terminals (but has 4).
我直接打开之前仿好的重新仿它就没报错,但复制电路重新新建一个去仿真都会出现这3个error,
发表于 2021-10-9 21:24:13 | 显示全部楼层
试一下把环境变量CDS_AHDLCMI_ENABLE设置成NO
发表于 2022-10-19 20:21:48 | 显示全部楼层
请问,楼主解决了嘛?怎么解决的?
发表于 2022-10-19 20:51:02 | 显示全部楼层
setenv CDS_AHDLCMI_ENABLE NO  试一试
GMT+8, 2025-12-18 16:56 , Processed in 0.013559 second(s), 4 queries , Gzip On, Redis On.
