查看: 2480|回复: 0
characterize时model读取有问题,”unable to identify the device type for..”
发表于 2021-10-2 17:17:59 | 显示全部楼层 |阅读模式
characterize时model读取有问题,”unable to identify the device type for..” 但是model中有n25_ckt的相关内容,请问需要做哪些修改才能成功运行?error如下:
ERROR (LIB-508): (char_library): Unable toidentify the device type for 'n25_ckt' because no global or local NMOS or PMOSmodel has been loaded using 'read_spice' and no 'define_leafcell' command hasbeen specified. Load the model using 'read_spice' or specify a'define_leafcell' command and rerun. The 'define_leafcell' commands mustprecede 'read_spice' command. If the netlist has elements, also specify the'-element' argument with the 'define_leafcell' command.
ERROR (LIB-507): (char_library): Failed toprocess the model based element inst: 'MM0', model: 'MOS' in the cell inverter.This cell will be skipped. Check the model uses standard parameter names andthe define_leafcell command options are used properly.  Update the Tcl script and rerun.
ERROR (LIB-203): (char_library): Cell'inverter' is scheduled for characterization but has no netlist, has an empty subcktor has no port on the subckt. This cell will be skipped. Check the netlist andrerun.
Char.tcl中读取model和spice语句:
set spicefiles$rundir/MODELS/include_models.sp
foreach cell $cells {
   lappend spicefiles ${rundir}/NETLIST/${cell}.src.net
read_spice $spicefiles
Model选用的是spectre:
simulator lang = spectre
include "newmodel/top*******.lib"section=top_tt
n25_ckt的相关部分:
subckt n25_ckt ( d g s b )
parameters
+w      = 1e-6            l       = 1e-6
Netlist如下:
.SUBCKT inverter GND VDD In Out
*.PININFO GND:B VDD:B
MM0 Out In GND net2 n25_ckt W=320n L=270nM=1
MM1 Out In VDD net3 p25_ckt W=320n L=270nM=1
.ENDS
GMT+8, 2025-12-15 15:53 , Processed in 0.063567 second(s), 4 queries , Gzip On, Redis On.
