发表于 2022-3-21 06:33:13
显示全部楼层
群主,您好,我启动用这个./dvt.sh
报错了,我是ubuntu18
[WARNING] Unable to find a working GTK and browser engine combination, using 'gtk3-webkit' (error F02__display_failed)
[WARNING] It means that this DVT distro flavor is not compatible with your OS, and crashes are likely to occur.
[WARNING] Possible fixes:
[WARNING] - Install/Update WebKitGTK library in your OS
[WARNING] - Download a DVT distro based on a different Eclipse version, currently you are using one based on Eclipse 4.19.0
./dvt.sh: line 594: 32519 Segmentation fault (core dumped) $commandline 2> >(tee -a "$DVT_LOG_LOCATION" | grep -E -v "$IGNORED_STDERR_PATTERN" 1>&2) > >(tee -a "$DVT_LOG_LOCATION" | grep -E -v "$IGNORED_STDOUT_PATTERN" 1>&2)
该怎么弄呀
