查看: 3716|回复: 4
[求助] 麻烦各位朋友分享一下一下这些文章!万分感谢!
发表于 2021-9-24 17:39:39 | 显示全部楼层 |阅读模式
1. A Current-to-Digital ∆Σ ADC for Low-Noise High-Precision Applications
Mitra Saeidi;Luke Theogarajan
2020 IEEE 63rd International Midwest Symposium on Circuits and Systems (MWSCAS)
2. A femto-ampere sensitive direct-interface current-input sigma delta ADC for amperometric bio-sensor signal acquisition
Ketan J. Pol;Hans Hegt;Arthur van Roermund;Sotir Ouzounov
2015 IEEE Biomedical Circuits and Systems Conference (BioCAS)
3. Efficient Broadband Current-Mode Adder- Quantizer Design for Continuous-Time Sigma–Delta Modulators
Chang-Joon Park;Marvin Onabajo;Hemasundar Mohan Geddada;Aydin Ilker Karsilayan;Jose Silva-Martinez
IEEE Transactions on Very Large Scale Integration (VLSI) Systems
4. A High Accuracy and Wide Input Voltage Range Current Sensor with Adaptive Amplification and Temperature Compensation
Huayi Liumin Xie;Cuiwen Li;Yanqi Zheng
2019 IEEE International Conference on Electron Devices and Solid-State Circuits (EDSSC)
5. Measuring and experimental results of current mode /spl Sigma//spl Delta/ modulators with switched transconductance
R. Suszynski
ICECS'99. Proceedings of ICECS '99. 6th IEEE International Conference on Electronics, Circuits and Systems (Cat. No.99EX357)
6. Design & Implementation of Low Power Delta Sigma ADC
Sheetal Saroha;Rajeshwar Dass
2020 7th International Conference on Signal Processing and Integrated Networks (SPIN)
7. A Low-Voltage and Low-Power Adaptive Switched-Current Sigma–Delta ADC for Bio-Acquisition Microsystems
Shuenn-Yuh Lee;Chih-Jen Cheng
IEEE Transactions on Circuits and Systems I: Regular Papers
8. A current-mode flash ADC for low-power continuous-time sigma delta modulators
Chang-Joon Park;Hemasundar Mohan Geddada;Aydin Ilker Karsilayan;Jose Silva-Martinez;Marvin Onabajo
2013 IEEE International Symposium on Circuits and Systems (ISCAS)
9. Low power continuous-time delta-sigma ADC with current output DAC
Niels Marker-Villumsen;Ivan H. H. Jørgensen;Erik Bruun
2015 European Conference on Circuit Theory and Design (ECCTD)
10. A dual channel 20 bit current-input A/D converter for photo-sensor applications
C. Binan Wang;J. Todsen;T. Kalthoff
2000 Southwest Symposium on Mixed-Signal Design (Cat. No.00EX390)
11. Balanced Low Noise High Dynamic Photodiode Interface for Automotive
Ivan Koudar
IEEE Custom Integrated Circuits Conference 2006
12. A Novel Read-Out Electronics Design Based on 1-Bit Sigma-Delta Modulation
Zhixiang Zhao;Qiu Huang;Zheng Gong;Zhihong Su;William W. Moses;Jianfeng Xu;Qiyu Peng
IEEE Transactions on Nuclear Science
13. A 24-bit multi-functional sensor analog front end employing low noise biasing technique with 8.2nV/√Hz input referred noise
Masahiko Maruyama;Shigenari Taguchi;Masafumi Yamanoue;Kunihiko Iizuka
2015 IEEE Asian Solid-State Circuits Conference (A-SSCC)
14. A Highly Digital VCO-Based ADC Architecture for Current Sensing Applications
Praveen Prabha;Seong Joong Kim;Karthikeyan Reddy;Sachin Rao;Nathanael Griesert;Arun Rao;Greg Winteravan Kumar Hanumolu
IEEE Journal of Solid-State Circuits
15. A current-measurement front-end with 160dB dynamic range and 7ppm INL
Chung-Lun Hsu;Drew A. Hall
2018 IEEE International Solid - State Circuits Conference - (ISSCC)
16. Design and modeling of a continuous-time delta-sigma modulator for biopotential signal acquisition: Simulink vs. Verilog-AMS perspective
Geng Zheng;Saraju P. Mohanty;Elias Kougianos
2012 Third International Conference on Computing, Communication and Networking Technologies (ICCCNT'12)
17. 0.13pW/Hz Ring VCO-Based Continuous-Time Read-Out ADC for Bio-Impedance Measurement
Mohammadhadi Danesh;Arindam Sanyal
IEEE Transactions on Circuits and Systems II: Express Briefs
18. An Energy-Efficient CMOS Biophotometry Sensor With Incremental DT-∑Δ ADC Conversion
M. N. Khiarak;K. Sasagawa;T. Tokuda;J. Ohta;S. Martel;Y. De Koninck;B. Gosselin
2018 IEEE International Symposium on Circuits and Systems (ISCAS)
19. A Low-Power Dynamic-Range Relaxed Analog Front End for Wearable Heart Rate and Blood Oximetry Sensor
Hao Zhang;Ye Li
IEEE Sensors Journal
20. A low-power high-sensitivity analog front-end for PPG sensor
Binghui Lin;Mohamed Atef;Guoxing Wang
2017 39th Annual International Conference of the IEEE Engineering in Medicine and Biology Society (EMBC)
21. A 1-V 8.1- μ W PPG-Recording Front-End With > 92-dB DR Using Light-to-Digital Conversion With Signal-Aware DC Subtraction and Ambient Light Removal
Fatemeh Marefat;Reza Erfaniedram Mohseni
IEEE Solid-State Circuits Letters
22. Multimodal Analog Front End for Wearable Bio-Sensors
Insoo Kim;Yusuf A. Bhagat;Johnny Homer;Ryan Lobo
23. A Current-Sensing Front-End Realized by A Continuous-Time Incremental ADC with 12b SAR Quantizer and Reset-Then-Open Resistive DAC Achieving 140dB DR and 8ppm INL at 4kS/s
Su-Hao Wu;Yun-Shiang Shu;Albert Yen-Chih Chiou;Wei-Hsiang Huang;Zhi-Xin Chen;Hung-Yi Hsieh
2020 IEEE International Solid- State Circuits Conference - (ISSCC)
24. A 28μW 134dB DR 2nd-Order Noise-Shaping Slope Light-to-Digital Converter for Chest PPG Monitoring
Qiuyang Lin;Shuang Song;Roland Van Wegberg;Mario Konijnenburg;Dwaipayan Biswas;Chris Van Hoof;Filip Tavernier;Nick Van Helleputte
2021 IEEE International Solid- State Circuits Conference (ISSCC)
25. Novel methodology for integrated analog front-end signal processing blocks based portable multifunctional sensor for biomedical applications
D. F. Cruz;E. M. G. Rodrigues;R. Godina;C. M. P. Cabrita;J. C. O. Matias;J. P. S. Catalão
2016 IEEE 16th International Conference on Environment and Electrical Engineering (EEEIC)
26. A Low-Power, Dual-Wavelength Photoplethysmogram (PPG) SoC With Static and Time-Varying Interferer Removal
Eric S. Winokur;Tom O'Dwyer;Charles G. Sodini
IEEE Transactions on Biomedical Circuits and Systems
发表于 2021-9-24 22:14:59 | 显示全部楼层
好多啊
发表于 2021-9-25 09:30:36 | 显示全部楼层
淘宝上几十块钱买个IEEE账号就好了
 楼主| 发表于 2021-9-27 16:11:41 | 显示全部楼层
我有IEEE账号,可是下载不了Paper,Paper锁住的!why?
发表于 2024-7-30 00:00:36 | 显示全部楼层
谢谢楼主啦
GMT+8, 2025-12-30 00:12 , Processed in 0.019325 second(s), 3 queries , Gzip On, Redis On.
