查看: 5321|回复: 7
ubuntu安装sentaurus后执行问题(已解决)
发表于 2021-9-20 13:34:59 | 显示全部楼层 |阅读模式
如题
在ubuntu1804上安装sentaurus后执行sde遇到如下提示
qt.qpa.xcb: QXcbConnection: XCB error: 14 (BadIDChoice), sequence: 858, resource id: 1, major code: 53 (CreatePixmap), minor code: 0
qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 859, resource id: 1, major code: 55 (CreateGC), minor code: 0
qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 860, resource id: 1, major code: 72 (PutImage), minor code: 0
qt.qpa.xcb: QXcbConnection: XCB error: 13 (BadGC), sequence: 861, resource id: 37748787, major code: 60 (FreeGC), minor code: 0
qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 862, resource id: 1, major code: 139 (Unknown), minor code: 4
qt.qpa.xcb: QXcbConnection: XCB error: 4 (BadPixmap), sequence: 863, resource id: 1, major code: 54 (FreePixmap), minor code: 0
qt.qpa.xcb: QXcbConnection: XCB error: 143 (Unknown), sequence: 864, resource id: 37748788, major code: 139 (Unknown), minor code: 27
qt.qpa.xcb: QXcbConnection: XCB error: 6 (BadCursor), sequence: 868, resource id: 37748789, major code: 138 (Unknown), minor code: 23
qt.qpa.xcb: QXcbConnection: XCB error: 6 (BadCursor), sequence: 869, resource id: 37748789, major code: 138 (Unknown), minor code: 23
qt.qpa.xcb: QXcbConnection: XCB error: 6 (BadCursor), sequence: 870, resource id: 37748789, major code: 2 (ChangeWindowAttributes), minor code: 0
qt.qpa.xcb: QXcbConnection: XCB error: 6 (BadCursor), sequence: 871, resource id: 37748789, major code: 2 (ChangeWindowAttributes), minor code: 0
请问下如何解决呢?
发表于 2021-9-20 21:34:12 | 显示全部楼层
别做无用功了。安装成功也只能算是不断排雷过程的开始。。。果断换centos
 楼主| 发表于 2021-9-20 21:46:12 | 显示全部楼层
哪个版本稳?7.4?7.6?7.9?
发表于 2021-9-22 19:46:08 | 显示全部楼层
7.9呗
 楼主| 发表于 2021-9-22 21:35:12 | 显示全部楼层
发表于 2021-10-24 00:07:39 | 显示全部楼层
qt的lib问题,export个debug的变量,按提示安装就好了
 楼主| 发表于 2021-10-24 09:04:37 | 显示全部楼层
有参考步骤么?
 楼主| 发表于 2021-12-26 18:57:36 | 显示全部楼层
1.按次序装好QT:https://blog.csdn.net/weixin_41477306/article/details/95743555
2.补缺少的库:https://www.pianshen.com/article/69392026250/
解决了qt.qpa.xcb报错。
GMT+8, 2025-10-6 00:55 , Processed in 0.020249 second(s), 3 queries , Gzip On, Redis On.
