楼主: hustjzr
(已解决)SPECTRE 211所支持新的FX仿真器FEATURE
 楼主| 发表于 2021-9-19 23:24:02 | 显示全部楼层
hitzhabc 发表于 2021-9-19 19:09
首先,那几个feature 是没问题的。其次,C家20版以后的和谐方法和18版不一样……你这是和谐不成功。 ...
您好,请问一下20之后的和谐方法能否提供一下某度链接
 楼主| 发表于 2021-9-19 23:25:36 | 显示全部楼层
amodaman 发表于 2021-9-19 17:19
Having added the two features you mentioned, I still got the license check out error saying requ ...
大佬,请问一下可以通过FEATURE name生成FEATURE吗,能否提供一下某度链接,我之前都是找的论坛里面改好的FEATURE
 楼主| 发表于 2021-9-19 23:30:56 | 显示全部楼层
shindziharan 发表于 2021-9-19 12:32
Unfortunately, I do not use graphics mode to set up / run the simulation, so I cannot tell if there  ...
Thank you for your attention. I noticed that when I use the SPECTRE 211 in ADE simulation, even the tran and dc simulations cannot run. The software reported that the license is unavailable. Maybe my old license is not applicable to the new version of the software. Or, the patch I am using does not work in the SPECTRE 211. Could you explain it more detail, or provide a patch or complete FEATURE for SPECTRE 191? Thank you~
 楼主| 发表于 2021-9-19 23:37:30 | 显示全部楼层
hustjzr 发表于 2021-9-19 23:30
Thank you for your attention. I noticed that when I use the SPECTRE 211 in ADE simulation, even th ...
sorry,i mean SPECTRE 211
发表于 2021-9-20 10:13:34 | 显示全部楼层
有spectre 211的软件链接吗?
PLS  用ocad的tool可以从licserver的log中看到check了哪个feature,然后加上就是
发表于 2021-9-20 11:10:35 | 显示全部楼层
hustjzr 发表于 2021-9-19 05:12
我的仿真平台是:
能提供此版本的cadence吗?
 楼主| 发表于 2021-9-20 19:44:12 | 显示全部楼层
如果需要211安装包,私信我一哈,大家看看有没有和谐办法哈
点评
点赞  发表于 2022-9-24 22:04
回复 支持 2 反对 0
发表于 2021-9-21 14:12:59 | 显示全部楼层
This is the installation package for SPECTRE 211
链接: https://pan.baidu.com/s/1y92t61blddRO4WCSLjvbhA 提取码: qzyf 复制这段内容后打开百度网盘手机App,操作更方便哦
Could anyone share the license crack?
 楼主| 发表于 2021-9-21 16:46:37 | 显示全部楼层
Hello, can you provide the details of the above FEATURE?
发表于 2021-9-22 05:03:29 | 显示全部楼层
What exactly do you want to know about the features?
First: to run Spectrefx in ADE_L goto Setup/Environment and type in "User Command Line Options": +fx
Note1: this line must not contain +postlayout or you will get an error.
Note2: enable the "Trace License Check-In and Check-Out" checkbox.
Second: goto Setup/High-Perfomance Simulation Options and choose "Spectre" and "Do not override"
Now the log should contain information about specific features that were needed to launch.
Report the results here, if errors appear, we will try to figure it out.
GMT+8, 2025-12-25 08:09 , Processed in 0.023579 second(s), 7 queries , Gzip On, Redis On.
