查看: 5968|回复: 9
[求助] 加密解密innovus tcl
发表于 2021-9-4 10:33:50 | 显示全部楼层 |阅读模式
悬赏1000资产已解决
谁知道如何加密解密innovus使用的tcl文件,比如下面的:
对于s家的工具,可以通过tbc加密,解密我不会
最佳答案
查看完整内容
Cadence AE 提供的使用说明, enjoy How To... Does Encounter/Innovus/Tempus/Voltus have the capability to encrypt Tcl files and read these encrypted Tcl files? Answer There is an encryption utility called 'fishenc' to encrypt Tcl files. The fishenc executable is available in the installation hierarchy of the Innovus tool. $install_dir/tools.lnx86/bin/fishenc You can use this command to encrypt Tc ...
发表于 2021-9-4 10:33:51 | 显示全部楼层
How To...
Answer
You can use this command to encrypt Tcl code files. Moreover, Encounter/Innovus/Tempus/Voltus can read these encrypted Tcl files.
Usage
unix> $install_dir/tools.lnx86/bin/fishenc a.tcl  # converts a.tcl to encrypted a.tcl
unix> innovus
innovus> source a.tcl                             # source encrypted Tcl file
innovus> exit
Note:
If the unencrypted Tcl file contains "line break" character formatted in DOS, then you will not see any error at the time of encryption, but the tool may error out at the time of parsing the commands from the encrypted Tcl file because of DOS formatted "line break" character..
To resolve this formatting issue, convert the DOS "line break" character to Unix "line break" character, using dos2unix command before invoking fishenc utility on this file:
unix> dos2unix a.tcl
 楼主| 发表于 2021-9-5 11:17:21 | 显示全部楼层
How To...
Perfect Answer!  Thank you
发表于 2021-9-5 12:32:24 | 显示全部楼层
举手之劳,不必客气。
如何把信元返还给你,我找不到转账操作在哪里了
 楼主| 发表于 2021-9-5 16:38:09 来自手机 | 显示全部楼层
jake 发表于 2021-9-5 12:32
举手之劳,不必客气。
好意心领了 不用退 谢谢jake
发表于 2021-9-7 09:30:17 | 显示全部楼层
谢谢分享~
发表于 2021-9-14 10:36:44 | 显示全部楼层
怎么解密啊?加密了改不回去了
发表于 2023-11-7 17:33:54 | 显示全部楼层
谢谢分享
发表于 2024-10-28 19:11:45 | 显示全部楼层
有没有大佬知道 Synopsys 怎么加密解密?
发表于 2024-10-29 10:41:23 | 显示全部楼层
谢谢分享
GMT+8, 2025-9-19 08:19 , Processed in 0.020450 second(s), 5 queries , Gzip On, Redis On.
