查看: 2026|回复: 1
[求助] impl run之后不显示时序余量
发表于 2021-8-13 21:50:41 | 显示全部楼层 |阅读模式
请问是怎么回事呢?通过report_clocks检查约束添加正确
电路功能很简单,两个无符号数相乘,输出结果延迟几拍输出。
当设置延迟3拍/4拍/8拍时,均有WNS数值
  1. // Unsigned 16x24-bit Multiplier
  2. // 1 latency stage on operands
  3. // 3 latency stage after the multiplication
  4. // File: multipliers2.v
  5. `timescale 1ns/1ps
  6. module mult_unsigned (clk, A, B, RES);
  7. parameter WIDTHA = 16;
  8. parameter WIDTHB = 24;
  9. input clk;
  10. input [WIDTHA-1:0] A;
  11. input [WIDTHB-1:0] B;
  12. output [WIDTHA+WIDTHB-1:0] RES;
  13. reg [WIDTHA-1:0] rA;
  14. reg [WIDTHB-1:0] rB;
  15. reg [WIDTHA+WIDTHB-1:0] M [4:0];
  16. integer i;
  17. always @(posedge clk)
  18. begin
  19.     rA <= A;
  20.     rB <= B;
  21.     M[0] <= rA * rB;
  22. for (i = 0; i < 4; i = i+1)
  23.     M[i+1] <= M[i];
  24. end
  25. assign RES = M[4];
  26. endmodule
  27.
    复制代码
但是设置为1拍/2拍时,就显示NA了
  9. input clk;
  15. reg [WIDTHA+WIDTHB-1:0] M [2:0];
  16. integer i;
  18. begin
  19.     rA <= A;
  20.     rB <= B;
  22. for (i = 0; i < 2; i = i+1)
  23.     M[i+1] <= M[i];
  24. end
  25. assign RES = M[2];
  26. endmodule
  27.
    复制代码
请问有人知道这是怎么回事吗
发表于 2021-8-30 18:04:38 | 显示全部楼层
2拍是不是算不完啊?
GMT+8, 2025-12-22 04:49 , Processed in 0.012677 second(s), 4 queries , Gzip On, Redis On.
