查看: 6266|回复: 11
[求助] 有人知道soft_bin=allmodels 如何解决嘛?
发表于 2021-8-12 11:25:59 | 显示全部楼层 |阅读模式
后仿真出现错误如下:
Error found by spectre during initialsetup.
   ERROR (CMI-2440): "input.scs" 24848: I0.I6_10__MNM0@2:  The length, width, or area of the instancedoes not fit the given lmax-lmin, wmax-wmin, or areamax-areamin range for anymodel in the `nch_33' group. The channel width is 2.000000e+00 and length is3.250000e-01. Specify channel width and length that do not exceed thereferenced maximal area Lmax=5.000100e-05, Lmin=3.250000e-07, Wmax=1.000010e-04and Wmin=1.350000e-07. You can choose the nearest model by setting the value of`soft_bin' option to `allmodels'.
   ERROR (CMI-2440): "input.scs" 72: I0.I6_10__MPM8:  The length, width, or area of the instancedoes not fit the given lmax-lmin, wmax-wmin, or areamax-areamin range for anymodel in the `pch_33' group. The channel width is 3.500000e+00 and length is2.800000e-01. Specify channel width and length that do not exceed thereferenced maximal area Lmax=5.000100e-05, Lmin=2.800000e-07, Wmax=1.000010e-04and Wmin=1.350000e-07. You can choose the nearest model by setting the value of`soft_bin' option to `allmodels'.
请问有人知道如何解决吗?
发表于 2021-8-12 14:34:46 | 显示全部楼层
看下option里面scale有没有设置对
 楼主| 发表于 2021-8-12 17:33:21 | 显示全部楼层
请问option是哪里的option  ADEL中的还是pex option?还是其他的
发表于 2021-8-12 17:49:19 | 显示全部楼层
ADE中的,看起来你的scale差了1e6
发表于 2021-8-12 22:38:51 | 显示全部楼层
 楼主| 发表于 2021-8-13 09:43:39 | 显示全部楼层
好的 谢谢!!
发表于 2023-10-12 14:17:52 | 显示全部楼层
请问这个soft_bin=allmodels是用来做什么的?
我仿真发现,当把scale=0.8 && soft_bin=allmodels,好像scale就不生效了。
发表于 2024-9-12 10:58:56 | 显示全部楼层
我仿真发现,当把scale=0.8 && soft_bin=allmodels,好像scal ...
说明手册原文:soft_bin=singlemodelsIf set to singlemodels, it is used only on non-binned models.Possible values are inglemodels, no and allmodels.
当尺寸不匹配,soft_bin选择no时会报错,选择allmodels会挑相近参数继续仿真。
发表于 2025-4-21 18:14:33 | 显示全部楼层
请问 这个soft_bin=allmodels 是在哪里设置的
发表于 2025-7-22 15:40:47 | 显示全部楼层
在Simulation-Options-Analog-Miscellaneous-翻到最下面,有一个可以添加arguments的地方,直接把这一个【soft_bin=allmodels】代码输入进去
GMT+8, 2025-12-27 17:35 , Processed in 0.018722 second(s), 4 queries , Gzip On, Redis On.
