查看: 2333|回复: 3
[求助] event复制,怎么不work?
发表于 2021-8-11 21:14:02 | 显示全部楼层 |阅读模式
为啥 thread2没有打印呢 ? expect的结果应该是[20] Thread2:wait for ev_b is over
 楼主| 发表于 2021-8-11 21:17:57 | 显示全部楼层
发表于 2021-8-11 23:17:54 | 显示全部楼层
标准里面这段后面还有一段:
When events are merged, the assignment only affects the execution of subsequent event control or wait
operations. If a process is blocked waiting for event1 when another event is assigned to event1, the
currently waiting process shall never unblock.
所以如果由正在等待event1的线程,而 event1被赋予event2,此时等待event1的线程将不会unblock;
所以如果想要ev_b等待线程能执行, ev_b = ev_a的执行必须要在wait(ev_b.triggered)之前;
 楼主| 发表于 2021-8-12 09:48:36 | 显示全部楼层
miccjiang 发表于 2021-8-11 23:17
标准里面这段后面还有一段:
When events are merged, the assignment only affects the execution of subs ...
ev_b=ev_a;这句话一定要发生在wait ev_b之前,否则wait ev_b的进程永远不会unblock。 我改了下,现在ev_b等到了
GMT+8, 2025-12-19 13:41 , Processed in 0.017515 second(s), 5 queries , Gzip On, Redis On.
